Help 91 S2
Old 03-29-2013, 04:53 PM
mhr
mhr's Avatar
Default Help 91 S2
My car had been stored for the winter.
This week
I changed the rear fuel lines.
Took off the valve cover to change the gaskets because I was getting oil in my spark plug holes.
Closed it all up and started it up.
Ran fine no fuel leaks or oil running from around the valve cover that I could see.
Took it for a short drive and it seemed to run well. Then the ! Light came on at idle because oil pressure was low.
I added some oil because it was low and tried to start it up. Was hard to start but started but EVERY light on the dash is on (oil level, oil pressure, voltage, brake wear, ABS) also the oil pressure reads 0.
Turned it off.
Any ideas where I should start looking?
Mark
Old 03-29-2013, 05:08 PM
V2Rocket
Rainman
V2Rocket's Avatar
Check wiring, some mouse may have snacked on your grounds over winter
Old 03-29-2013, 05:26 PM
mhr
mhr's Avatar
Don't think I have mice in the house but will look around.
Old 03-29-2013, 05:40 PM
J Berk
J Berk's Avatar
guessing either mice or maybe you left something disconnected when you put it all back together?
Old 03-29-2013, 05:46 PM
StoogeMoe
StoogeMoe's Avatar
Check your battery terminals.
Old 03-29-2013, 07:41 PM
mhr
mhr's Avatar
so I checked the battery terminals and they look good. Disconnected anyways and reconnected. No difference.
The car seems to be running great just all of the dash lights are on. Interestingly when I take off the parking brake that light does go out.
Any ground specifically related to the dash lights that I can check first?
Mark
Old 03-29-2013, 10:37 PM
gtroth
gtroth's Avatar
Just for the heck of it check your crank bolt.
Old 03-30-2013, 12:57 AM
mhr
mhr's Avatar
Some fuel went into the hole in the passenger fender after I changed the lines as one of them was not tight enough. Anything in there that could have been messed up and causing me the issue?
Old 03-30-2013, 09:17 PM
mhr
mhr's Avatar
No sign of mice or frayed wires anywhere. Tomorrow I will clean/tighten grounds hoping that will solve it.
Old 03-30-2013, 09:32 PM
veleno
veleno's Avatar
Good luck with solving the problem. I hate it when you can't figure out what's wrong even when nothing appears to be wrong! What would happen if you disconnect the ecu for a couple of minutes and reconnect? Worth a shot if anything but you'll never know what caused the lights to turn on...
A thought just came to mind... On my Lexus all the lights came on and it was caused by a bad brake sensor at the pedal.
Old 03-30-2013, 09:59 PM
pontifex4
pontifex4's Avatar
Does the oil pressure still read zero? Are all the other gauges working?
Old 03-30-2013, 10:50 PM
VaSteve
VaSteve's Avatar
There is an electrical connection at the very front edge of the valve cover. That's about where the oil pressure sender is. I don't recall if that's where the actual connection is. I'm betting that the VC didn't come off easily and something got disturbed in the process. Check your work. Good luck!
Old 03-31-2013, 09:32 AM
mhr
mhr's Avatar
off to the garage in about 15 minutes.
Charlie
Yes oil pressure shows 0, Hard to say if the temp is working because I don't run it for long enough for it to heat up. Gas gauge it working and volt is working. All warning lights are on.
Thanks for the help so far!
Old 03-31-2013, 10:55 AM
Jfrahm
Jfrahm's Avatar
I would check the ribbon connectors to the cluster, they can get loose, particularly if the locking ears get broken off.
Old 03-31-2013, 11:44 AM
ralaisa
ralaisa's Avatar
I had oil low level light on and it was because the ground wires for the electric fans were frayed.
Take a look by the battery at the round resistors on the firewall. Checks those wires. Weird I know, but there is a lot of current going through them and the cars and wires are getting old.
Quick Reply: Help 91 S2
