Discrepancy between stock tach and aftermarket tach
WRONGLY ACCUSED!
Received 4,092 Likes
I installed an Autometer shift light which has a digital tach readout in the center of the tach. It is pretty nice.
One problem - the digital tach consistently reads 300 RPMs less than the stock (dash) tach.
I double checked my wiring and settings and everything appears to be correct.
Anyone have any thoughts on the reason for this difference?
Thank you.
Thank you.
You can always call an AutoMeter rep and ask, they probably get that a lot.
Running it to the limiter isn't the best idea, especially on an unloaded engine.
I think its fine.
However, I'm not an expert, so either call a rep or wait for another response!
Take care!
WRONGLY ACCUSED!
My S2 tacho also reads around 200-300 rpm higher than what the real rpm is as logged by my datalogger directly from the DME. I would say the error is with the stock tacho.
WRONGLY ACCUSED!
Thanks for the additional input. My tach is wired to the coil, not the DME, so I guess that rules out that variable as well.
Given the other comments, I think the discrepancy is probably normal.
BTW, sending you a PM
Take care!
Small Business Partner
Yep - the stock tach is typically a bit optimistic. I've verified this across both internal DME logging, and external loggers.
