Help Coilovers hit transaxle oil cooler
Old 01-19-2012, 03:06 PM
  #31
Olli Snellman
Olli Snellman's Avatar
Those are what i have. I made first drawings and my friend fabricated a first set for me. Now he have those for sale.
Old 01-19-2012, 03:50 PM
  #32
MAGK944
MAGK944's Avatar
Originally Posted by ModdedEverything951S
No t-bars, didn't go with sphericals so no crazy mounting bolt needed...
Can I see Delrin in that bottom mount or are they all rubber or some sort of poly? Also interested in what spring rate you can use without going spherical in there.
Old 01-19-2012, 03:56 PM
  #33
Lemming
Lemming's Avatar
Originally Posted by 67King
Going to run an external cooler. They can be found inexpensively at www.racecityraceparts.com.
I've been happy with coolers (oil and two intercoolers) from CXracing on ebay. The oil coolers are 1/2 the cost of the name brands.
Old 01-19-2012, 03:57 PM
  #34
Darwantae951
Darwantae951's Avatar
In all honesty, I do not know if it's Delrin or poly. It was installed when I recieved them. I run 500lb springs in the rear.
Old 01-19-2012, 04:59 PM
  #35
xsboost90
xsboost90's Avatar
i would change those bottom mounts- the factory bolts do not have the shear strength to hold the car up and will eventually break off. Seen it before.I ran Racer's Edge mounts for a few years.
Old 01-19-2012, 05:18 PM
  #36
Darwantae951
I am running the factory bolt at the recommendation of Karl at RE. He spec'd my set-up, and I asked about the lower bolt. He said that because I wasn't going with spherical joints, that the stock bolt is fine.
Old 01-19-2012, 06:53 PM
  #37
Oddjob
Oddjob's Avatar
Can only use the factory bolt when running the stock type rubber bushing shock mounts, like bilstein and the older koni shocks.
And I would not agree that the factory grade 10.9 14mm bolt is weaker than the 1/2" (12.7mm) aftermarket adapters.
Old 01-19-2012, 08:24 PM
  #38
johntorg
johntorg's Avatar
Mine has rubber bushings top and bottom in my 944Cup/GTS1 car. So far so good. The monoball setup went in to a widebody turbo race car GTS4 or 5. It had 28mm torsion bars before the conversion.
Old 01-20-2012, 01:39 PM
  #39
dontnow
dontnow's Avatar
Nice looking car John. What wheels are on that? Early offset?
Old 01-20-2012, 10:59 PM
  #40
johntorg
johntorg's Avatar
I think they were speedlines, but I didn't get them with the car. I now have 17" BBS 3 piece with mag centers. 275s in front and 315s in the rear. Its a widebody 88 Turbo S, so its late offset.
Quick Reply: Help Coilovers hit transaxle oil cooler
