my 944 has power steering but...
the steering in my 85.1 944 is fairly stiff as if it is not power assisted. i have a full reservoir, the belt is new and is tensioned properly, no leaks what so ever. the steering does not return to center on its own, i have to help it and guide it back. there's something that i'm missing with my diagnostic efforts. i don't know if the rack is binding or if perhaps i need to clean and grease a steering universal joint or yolk..maybe there's another issue that i'm overlooking. i checked clark's garage but thought i'd also post here in search of an answer.
there is a ps cooler in the ps front bumper cover. Pull the lines from each side and blow compressed air through. They commonly get crap clogged up in the loops. My turbo was alittle stiff and once i cleaned it out and put new fluid in they steering was wayyyyy better.
the pump doesn't have a choice but to pump as the belt is connected and tensioned properly. i believe that if the internal vanes were bad the power steering pump would make noise. i don't even hear the pump whining at full lock or when turning the wheel.
good call on the degredation of the pressure line on the cooler when placed in the hot tank. i think i can get at the cooler from the right front wheel well..
I'll go out on a limb here and disagree with what's been suggested. *I would be looking at caster, wheel bearing or toe wear for your lack of self centering. Castor has the most effect on self centering, it will also make your ps seem stiffer if it's not set correctly. When did you have your last alignment?
Even with no oil in the rack or a manual rack it self centers if the alignment is correct.
i can't say for sure when the last time was that the car was aligned. i can however say that the tires have no uneven wear, are not choppy, and the car tracks perfectly straight. it does need control arm bushings but i think that's the least of the cars issues.
You cannot adjust Castor on these cars but a number of factors will change it. An alignment might show it's wrong but that isn't always reliable as the Castor issue might only happen when the car is moving.
Issues that will cause bad Castor are:
1. Worn top mount bearing/bushings.
2. Loose damper in strut.
3. Bad control arm bushings.
4. Under-inflated tires.
5. Bad track control arms.
