my 951 is pushing 20 plus lbs please help
Old 06-27-2011, 02:43 PM
Griffin951
Griffin951's Avatar
Exclamation my 951 is pushing 20 plus lbs please help
I have a 86 951 and the gage is saying im pushing almost 2 bars which is about 28 lbs. i know stock is 11 and i need ideas on what to do so i don't do any damage also i was told that there is a stage 2 chip set in it from the previous owner if that makes a difference
Old 06-27-2011, 02:47 PM
doabarrelroll
doabarrelroll's Avatar
Hehe, the gauge reads pretty poorly on the dash.
Get an additional boost gauge and that will give you the true reading.
Old 06-27-2011, 02:50 PM
Griffin951
Griffin951's Avatar
So im guessing if i actually was pushing 20+ my car woulda blown already and where could i get a new gauge
cpcca
cpcca's Avatar
1.75 bar is normal
Old 06-27-2011, 02:52 PM
Griffin951
Griffin951's Avatar
Im new to porsche stuff and if 1.75 is normal what is it actually pushing
Old 06-27-2011, 02:55 PM
944obscene
944obscene's Avatar
The gauge reads Armo+boost. You're only really seeing 14 at most. Probably closer to 11 or 12. And yeah... not always spot on either.
Old 06-27-2011, 02:56 PM
Griffin951
Griffin951's Avatar
whats Armo and would a chip set bump it up the boost alittle
Old 06-27-2011, 03:01 PM
944obscene
944obscene's Avatar
GAH! My phone. Atmo as in atmospheric...
Old 06-27-2011, 03:04 PM
Griffin951
Griffin951's Avatar
hahaha o ok thanks
Old 06-27-2011, 03:05 PM
xsboost90
xsboost90's Avatar
yes you will not actually be into boost until you see the factory gauge at one bar. 20psi and you would notice a huge difference in power but i doubt the factory wastegate would allow it.
944obscene
944obscene's Avatar
Aftermarket/reburned chips are designed to remove the overboost protection and remap fuel etc. I have chips for stock turbo, 16 pounds iirc. I'd have to get details on the rest of the specs. I have them somewhere. Never got a chance to install them
Old 06-27-2011, 03:08 PM
Griffin951
Griffin951's Avatar
ill have to crack open my car and see what kind of chip sets are in it, who sells good chipsets
Old 06-27-2011, 03:35 PM
cpcca
cpcca's Avatar
New to 944 go here for some very solid info: http://www.clarks-garage.com/
944 obscene is correct. to help understand it: assume armo is just a a typo for atmo for atmosphere (atm). 1 atmosphere = ~14.7 psi (at sea level) which is the ambient air pressure we live and breathe in.
1.75 bar = 1.73 atm = 25.38 psi-14.7=10.68 psi boost over ambient
Handy converter here: http://www.unit-conversion.info/pressure.html
Performance Mods are endless. Read up before you spend a dime!!
Lindsey Racing (www.lindseyracing.com) and Vitesse (www.vitesseracing.com) are highly regarded names for mods at all levels. Clarks has a good overview discussion.
good luck and welcome~
CC
Old 06-27-2011, 04:30 PM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
www.roguetuning.com
Quick Reply: my 951 is pushing 20 plus lbs please help
