N-Tune
Old 10-10-2012, 10:02 PM
  #346
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Agreed that measurement is better than guesswork... which is why I'm doing all the dyno-quantifications!
The 944S used pretty much the same size throttlebody, and at >30hp more than the 944NA, so I think the majority of the gain there is simple from the better head-flow. Yes, the DOHC has a better combustion chamber and higher CR - but, I bet the real hp increase came from head-flow.
So, trying out a more aggressive camshaft will hopefully bring good results! We will see.
What I'm trying to do is keep with fairly simple bolt-on modifications that don't require any/minimum fabrication.
After the camshaft, I will probably test out the 951 intake, throttle-body, & S2 airbox setup.
What does everyone think about a true equal-length header?
How about a milled cylinder head (to raise compression)?
Old 10-10-2012, 10:04 PM
  #347
V2Rocket
Rainman
V2Rocket's Avatar
I have some funky headers I'm wanting to try out on my car. Not equal length, but longer primaries than stock by a good margin. Don't have any idea who made them but they look cool. If you want to give them a shot I could loan them to you...
Old 10-10-2012, 10:18 PM
  #348
Rogue_Ant
Rogue_Ant's Avatar
Originally Posted by Jamesr6967
Josh :
I need my car to appear 100% stock. Can a stock AFM be gutted and fitted with your MAF sensor (possibly sleeved or gutted and 'wrapped' around your tube) ?
Is this for emissions reasons or other..? Feel free to PM/Email me, if you want to take it offline.
Thanks for the offer, but if I do headers, then it will probably be one by Dave, http://www.frontrangefabrication.com/.
Old 10-11-2012, 04:32 AM
  #349
catamax944
catamax944's Avatar
Josh :
Someone in the turbo forum did that with a scivision maf
Old 10-11-2012, 07:52 AM
  #350
Jamesr6967
Jamesr6967's Avatar
Iirc 'tri-Y' headers are meant for bottom end torque and power (up to 6k rpm or so), equal length are better suited for higher rpm power at the expense of bottom end power and driveablity.
Old 10-11-2012, 10:11 AM
  #351
MG944
MG944's Avatar
Just an observation, I can measure and post the differences later but early and late mid pipes have a different length Y in the mid pipe. Early cars are shorter by... Six inches or so (initial guess).
The cam will be cool for comparison and a shaved head will provide a good chunk of information for those of us that will need to do head gaskets later on down the road. How far are you thinking of shaving the head? 11:1 or more? How far car a na head be shaved realistically?
Old 10-11-2012, 11:00 AM
  #352
F40LM
F40LM's Avatar
Default 4• offset key
Don't mean to hyjack thread, figured someone reading this thread would be interested.......
I ordered 2 offset keys from 928 motor sports this morning and requested both of them to be 8 valve (early) at 4 degrees. Just like Josh suggested.
If you would like the 'spare' and have $21 laying around send me a PM.
Old 10-11-2012, 07:38 PM
  #353
Rogue_Ant
Rogue_Ant's Avatar
Generally yes. Though some of the import guys have been doing long-tube tri-Y which seems to not sacrifice much high-end power (unlike a traditional tri-Y).
That is interesting, and also works along the same idea that I just mentioned: having a long-tube tri-Y.
I'm not sure how much I can shave the NA head... I bet some of the spec-racing people would have the answer? Additionally, this brings up the question of if I should use an NA or 951 head?
Old 10-11-2012, 07:50 PM
  #354
J1NX3D
J1NX3D's Avatar
out of interest is the difference between 1985 or 1985< cars? or 83-87 vs '88< cars?
Old 10-11-2012, 08:23 PM
  #355
Rogue_Ant
Rogue_Ant's Avatar
And these threads/people are the reason that I don't post much on Pelican:
http://forums.pelicanparts.com/porsc...986-944-a.html
http://forums.pelicanparts.com/porsc...n-here-10.html
It seems that no matter how good my intentions, I always get my head bit-off on that forum...
Old 10-11-2012, 09:19 PM
  #356
MAGK944
MAGK944's Avatar
He's an idiot, don't let it get to you.
Is it any wonder that all the best product development for our cars happens over here.
Keep up the good work!
Old 10-11-2012, 10:45 PM
  #357
86 951 Driver
86 951 Driver's Avatar
People never seize to amaze me. I think you did a good job on putting a true NA Maf together. Most people with an N/A don't want to spend $500 on something unless it gives a huge gain. That is part of the reason for supercharger kits not doing well even budget kits will fail.
If I still had my 924S I would think about doing this upgrade. I look forward to getting one of your kits for my 951. No one realizes how much time is spent getting this all programed and bugs worked out. If they knew they they could see why the price tag is $500.
Old 10-12-2012, 12:10 AM
  #358
J1NX3D
J1NX3D's Avatar
i'm mad924 on pp. fwayfarer is star poster on that forum. never seen anyone quite like him. mike is usually a stand up guy, not sure why hes getting so bent up. forums arent the perfect platform to straighten out misunderstandings though.
Old 10-12-2012, 01:20 AM
  #359
MG944
MG944's Avatar
My 87 has the long y mid pipe and I picked up one off an 84 that was a shorter one. So my guess would be the early/late split
Old 10-12-2012, 01:22 AM
  #360
Jamesr6967
Jamesr6967's Avatar
I have an '83 NA as well as a '85.5 NA parts car. I can measure the Y on the header, will be a few days tho as I'm out of town.
Quick Reply: N-Tune
