N-Tune
Old 10-02-2012, 03:33 AM
  #256
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
I expect similar % gains regardless of USA/RoW/ect.
Old 10-02-2012, 07:38 AM
  #257
Eric_Oz_S2
Eric_Oz_S2's Avatar
Originally Posted by mikey_audiogeek
Sweeeeeeet - roll on the S2 version!
Cheers,
Mike
You said it Mike!
Old 10-02-2012, 08:10 AM
  #258
ZR8ED
ZR8ED's Avatar
Originally Posted by Rogue_Ant
plug-n-play wiring adapter (so that it plugs into the stock AFM plug); the chipboard w/ software.
As with all my Tunes, it does require a 28pin DME.
You had me right up to the 28pin DME. Does this "chipboard" allow/convert my dme board? Mine is an 86/na with a 24pin DME. Do I need to find a newer DME? Please elaborate. I'm a bit confused now...or maybe I just need another coffee this morning.
Old 10-02-2012, 01:27 PM
  #259
jd159
5th Gear
jd159's Avatar
Please work on one for the 16v S!! I've got a lot of mods on mine, headwork, bigger valves, cams etc. I'd love to see a 15hp or 20hp in gains.
I am curious though because this package comes with a chip and software. Are the gains due to the MAF alone or improved software? I already have a custom chip installed.
Old 10-02-2012, 02:56 PM
  #260
MarkX0
5th Gear
MarkX0's Avatar
I really cant wait to get my hands on this. easy installation and no more hesitation from that flappy AFM!!! I bet my 924S will feel like a brand new car and better!
Old 10-02-2012, 05:29 PM
  #261
Rogue_Ant
Rogue_Ant's Avatar
You have the correct DME, now it just needs to be converted to 28pin.
See here (for the 951, but same principle):
http://www.roguetuning.com/dme_conversion
Yes, the S/S2 are next... I expect similar % gains for these cars as well.
The gains are from the MAF and improved software. Additionally, to properly understand the MAF sensor, you will need my software. The AFM and MAF are fundamentally different sensors (volume vs mass), and have different flow vs voltage curves. This, among other things, needs to be dealt with by the software.
At WOT there is a good improvement, but the real strength is during normal driving - it feels so much stronger!
Old 10-02-2012, 08:26 PM
  #262
harrisonrick
Captain Obvious
harrisonrick's Avatar
If the S version comes out, sign me up bro...excellent work! PM me or email me with info to: harrisonrick@sympatico.ca
Well done!
Old 10-03-2012, 04:58 AM
  #263
101geo
Cruisin'
101geo's Avatar
Put me down for the S2 version as well.
Old 10-03-2012, 09:49 AM
  #264
Hagbard
Hagbard's Avatar
another future S2 customer here, too
Old 10-03-2012, 12:58 PM
  #265
Indy Rev
Indy Rev's Avatar
+2 S2
Old 10-03-2012, 05:41 PM
  #266
Rogue_Ant
Rogue_Ant's Avatar
Im a little surprised how many S/S2 people are showing up!
I wil do a kit for the S/S2, when I have more info I will post it up.
Old 10-03-2012, 09:10 PM
  #267
mikey_audiogeek
mikey_audiogeek's Avatar
"We are the Borg. Lower your shields and surrender your ships. We will add your biological and technological distinctiveness to our own. Your culture will adapt to service us. Resistance is futile"
Old 10-04-2012, 01:10 AM
  #268
J1NX3D
J1NX3D's Avatar
i like the cut of your gib lol
Old 10-04-2012, 02:13 AM
  #269
Rogue_Ant
Rogue_Ant's Avatar
Ok, so the resonator came in today
It is a 4" round, 22" long body stainless steel magnaflow - it should mellow out the exhaust rasp and give it a really nice tone.
We will put it in tomorrow. Additionally, the K&N filter should be here tomorrow as well, so I will do some back-to-back testing to see if there is any quantifiable gains.
Friday, I will put on the offset camshaft key. I will test it both retarding the cam and advancing it. On a single-cam engine, changing the cam timing simply shifts the power: retarding the cam tends to make more power up in the higher RPMs, while advancing it makes more power down low...
If things go as planned, then I will see about another few dyno runs this weekend.
Old 10-04-2012, 03:12 AM
  #270
Chunkerz
Chunkerz's Avatar
Sweeeeeeeeetnessss!!!! How much did the resonator cost? I might add one to my Christmas list as well.
Quick Reply: N-Tune
