no start ...
#106
My fuel pump doesn't make much noise but I'm sure if someone can slide under the right rear corner a bit and put a hand on it (while cranking) it should be obvious if it is running. If the check valve is working properly and there are no leaks elsewhere, the pressure should stay up when you stop cranking. If you open the fuel rail at this point and no fuel sprays out, you are not getting fuel (or very little). BTW, the fuel filter wouldn't have any effect on ease of cranking- the load on the electrical system from the fuel pump isn't going to have a significant drain on the electrical system.
#107
Also, you can test the speed/ref sensors with an ohm meter (per Clark's for specs IIRC). Typically, if the tach bounces and you're getting spark, they are good since they are two of the minimum inputs the DME must have before it will cooperate.
#108
rgs944, I think you mentioned it in a post somewhere else (that I can't find now) but what are you using for the rear fender stone shields? I think that looks good on a white car. Did you have to modify them?
#109
ok well, back with some results
put in the fuel pressure gauge
jumped the relay
fuel gauge shows 36 - which it should - new fuel pressure regulator
not sure what the gauge should show when I am cranking the car though
also, when we went to remove the gauge - fuel started spraying form the end of the fuel rail
I think I'm going to wait a bit for gas that sprayed out to evaporate, then will try starting the car again
this has been a nighmare ... could it be weak spark?
jumped the relay
#110
I haven't read the whole thread for a few days, so I'll ask some basics...You have fuel pressure, that is good. Have you tried pulling an ignition cable and check the spark with a spark plug? Easy tester..http://www.harborfreight.com/automot...cker-4424.html
To check the injector pulse..use a noid light..http://www.amazon.com/Wilmar-Piece-E.../dp/B0002KO4I2
You can also make your own, but I don't know if it is any cheaper.
With the noid light, you verify the injectors are getting pulses, and the spark test obviously checks for sparks.
#111
I wouldn't expect the fuel pressure to change during cranking. Try it again and then immediately pull a plug. If it looks/smells of raw fuel then you'll have to dig deeper in the weak/intermittent spark department. How long did you let it crank? Maybe try a little ether again to verify something will burn.
#112
let it crank for a few seconds, certainly enough to start
we want to try to jump start it from another car ... though I doubt this would work
maybe something is wrong with my new "autozone" starter? when we first put it in we forgot that one little cable - and car would turn but never start too ... but I don't have another good one to check ...
#114
#115
at the moment I have 3 DME's - 1 from the car, 1 I ordered before, and 1 I ordered from Pelican last week
but if I hear the pump turn on while the car is being cranked ... wouldn't that eliminate the DME?
#116
