you'll think you died and went to heaven...
#61
Today I got
My Custom Title
My Custom Title
I'd prefer to keep my cat since it's a newish magnaflow. I have a friend with access to a tig welder (he goes to school for welding at EVIT) Is it a problem to have half your exhaust new pipes and the other half stock pipes? And 2.5's are 2.5" stock right?
#62
B) Do you mean stock was 2.5 inch? probably not I'm talking 2.5" Diamter tubes
C) You'll be fine running half bigger diameter than, and it'll probably be good for few more ponies as well. Biggest pony gains will be had by doing replacing the exhaust manifold with headers, and going back from there, but if you just want a nicer sound with a better muffler than you're 17 and allowed to have the loudest and most annoying exhaust you please
When I was 17 errr (19 but whos counting) I didn't even run a muffler on my SAAB, just one cat in a 3.5" down pipe from the turbo, and when I was 18 I ran my 914 on straight headers for a couple weeks
#63
Today I got
My Custom Title
My Custom Title
Haha. Yeah the 944 has 2.5" diameter pipes stock.
My sound system's too nice to have a super obnoxious exhaust in the way
I'll take a vid of my exhaust as it is right now, after school. It's already loud and sounds raspy, I think my stock muffler's gone to crap.
#64
Yeah can go bigger than a 2.5" if you want maybe a 2.75" or 3" but you're more than likely only going to be shifting the powerband up
#65
Rainman
944 is closer to 2-1/16" stock pipe diameter, not 2.5", that was the 951. You can put a 951 muffler section on a 944 if you swap the pipe flange. No need to increase pipe size though below 200HP, it will just make it louder and slower. A car like a 944 which has no low-end to speak of needs as much gas velocity as it can get, so stock pipes are good enough for a street car.
#66
Today I got
My Custom Title
My Custom Title
So how do I weld this SLP resonator that's 2.5" on my 2.25"ish exhaust? And no I don't want to change up my while exhaust and the pipes!!! I just want to add muffler and resonator!
#67
but in answer to your question with a 2.25 to 2.5 piping adaptor duh!
pipe is cheap, don't be a tight ***
#68
That being said, it has been over 6 months now, my car has a stripped back end, and I drive it over two hours a day. So I think I will be swapping the IMCO muffler out. My plan is to do a exhaust bypass valve with remote in the car mounted just in front of a quieter muffler. Then on those days I really want alot of sound I can hit the bypass and really wake the dead. The system should still sound really good with a quieter muffler. It's the SLP resonator that really gives the great tones I think; I HIGHLY recommend it.
Again many thanks for putting this on the forum.
michael
#70
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
after doing the math, it was determined that to get to the correct sized tire to make 25.0 mph/1000 rpm [and 162.5 mph redline], it would be necessary to run 25.5" tires..... and upon buying my new, 18" rims, i found that the y-rated Dunlop 275-35-18s would fit the bill, measuring about 25.6"
after changing to the Dunlops, my speedometer, as confirmed both on by gps, traffic displays and mile markers was still exaggerating my actual speed by about 4 mph at 100~150 mph...... but, at 4000 rpm on the tach, my speed was exactly 100 mph [confirmed], exactly as the tire rotations/mile/tach/mathmatics indicated it should be. this means that my speedo had been exaggerating even more with the 25.0" Bridgestones mounted on the old 16" rims. [this situation has also been observed over and over and over with every 80s/'90s P-car, LOL].
so, i simply turned back the speedo just a tad under 5 mph [gently with my index finger] leaning on the butt side of the needle [caution]....
now, at 4000 rpm, the speedo correctly reads 100 mph, and 150 mph @ 6000 rpm, etc.
i was able to reach top speed with the open pipes.
if i set the tack on 2400 rpm, it takes exactly 10 minutes to go 10 miles [as it should], and the odometer differs from the mile marker signs by about 1/10th of a mile for every 100 miles...
this is just for the 968 box. i have no idea what would be required for 3 or 4 different 944 boxes.
#73
Today I got
My Custom Title
My Custom Title
Anybody have any used magnaflow or borla mufflers laying around?
And btw my plan is to NOT visit a shop.
Edit:
Is this what a stock exhaust should sound like..?!?!?!?!
(i had a little fun with my new laptop and windows movie maker lol)
Edit:
#74
Just replace the muffler with the resonator, you stilll got a cat on, shouldn't be too loud.... and if it is, than you're the worst 17 yr old kid ever
the slight increase in volume you have is probably from the aftermarket cat you put on, they don't muffle as much as factory units do
#75
Team Owner
with a turbo, that would be a sick idea with likely, very good results.
not sure about his n/a 4 keg motor and headers.
i think he'll get pulled over.
