alllllmost done.... build pics
Old 11-10-2009, 06:19 PM
  #46
Cass944
Cass944's Avatar
dumb question... AOS would be what? the port on the top of the oil filler?
Old 11-10-2009, 06:34 PM
  #47
krystar
krystar's Avatar
air oil seperator. yea the top port on the filler tube.
i wanna know about the nipple on the booster check valve also....cause mine's not connected to anything and i still get good pedal pressure. i've driven it at multiple test and tunes and track day also. So it's not something that's super critical...but I'd like to know what it's for still.
Old 11-10-2009, 08:17 PM
  #48
Cass944
Cass944's Avatar
i posted a link on the last page showing where it goes. 944online has a nice diagram. all it does is help open up some valve in the heater controls
http://944online.com/cgi-bin/ASI_Sto...tecontrol-9442
also, do you run a vacuum rez? i think i actually threw mine away...
Old 11-10-2009, 08:42 PM
  #49
V2Rocket
Rainman
V2Rocket's Avatar
vacuum reservoir is what that little nipple hooks up to.
it helps you stop if the engine is off and you need to use the brakes.
if the engine goes off be prepared to press HARD.
Old 11-10-2009, 09:37 PM
  #50
krystar
krystar's Avatar
ah, that makes sense. but we're in a manual car. even if ignition died or fuel died, if the car is still in gear, the engine will still make vacuum. i guess if the timing belt snaps, then u wouldn't be having vacuum.
i've had to use brake w/o engine. i'd be able to slow down...but def not STOP highway speeds. .
Old 11-10-2009, 10:36 PM
  #51
marky522
marky522's Avatar
Dont forget hte HVAC needs a vac source also.
Mark
Old 11-10-2009, 11:11 PM
  #52
krystar
krystar's Avatar
that's just on later cars right? ....the heater valve on my 83 is manual. was linked up by a cable.
Old 11-10-2009, 11:13 PM
  #53
Cass944
Cass944's Avatar
ok well i didnt get super far tonight because ive been sick all day... but i did get some small things done.
plugged this...
plugged this
i also plugged the port on the bottom of the J-boot but didnt get a picture.
vacuum lines are all run...
cant figure out where the heck this stuff goes.
the plug coming out of the hole is for the wiper motor i think... but i dont know where the plug for the heater blower fan goes... and im pretty sure something plugged into the top of the blower box onto that white strip with the pins but i have no idea what.
end result for the night
oh also got the brake lines run temporarily to make sure i had them all
Old 11-11-2009, 12:19 AM
  #54
Cass944
Cass944's Avatar
a few more things to add to the list of junk i need/or am missing...
1: the coolant flange thing that goes on the head that has the bleeder screw in the top of it (dont know how the heck i lost that...)
2: the bolt that goes through the alternator and bracket to hold it in place... i somehow still have the adjustable strut thing though.
3: new oil pressure sender....
4: throttle cable... i have the cable for the cruise control but not the one for the throttle... wtf
Old 11-11-2009, 01:31 AM
  #55
krystar
krystar's Avatar
lol are u gonna drive with the cruise control only? hehe
i got an extra oil pressure sender
Old 11-11-2009, 02:28 AM
  #56
Cass944
Cass944's Avatar
yeah? i have my old one but i remember my oil pressure light randomly turning on and my ! flashing at me every once in a while because i think it was going bad. so i COULD re use it but i suppose if you want to let go of yours for cheap..... hehe
so thats 2 things i need to come down and pick up from you now
Old 11-11-2009, 01:48 PM
  #57
Cass944
Cass944's Avatar
anyone have a coolant flange i can have?
or the long bolt that goes through the alternator to hold it to the bracket?
ill pay for shipping/beer
Old 11-11-2009, 01:59 PM
  #58
krystar
krystar's Avatar
shipping alcohol across state lines is a no-no :P
Old 11-11-2009, 02:18 PM
  #59
Cass944
Cass944's Avatar
i just give you the money, you purchase beer heh
Old 11-11-2009, 02:26 PM
  #60
V2Rocket
Rainman
V2Rocket's Avatar
id find another of those vacuum caps for the lower intake port, that hose and bolt thing will get in the way of installation and take away from your clean look
Quick Reply: alllllmost done.... build pics
