How much power can a k26 support?
that'd be RWHP...
and i believe the motor has stock internals and nothing ported or polished. i didnt see anything of the sorts in the receipts, i believe the motor was just sent to a machine shop and redecked for a clean even surface after years in storage...i'm going to somehow try and figure out what sort of hotside is on it because the receipts say that the turbo was swapped over and resealed...would a #10 hotside sound right?
Very interesting. About a year ago I came across another 951 with that same MAF setup that was running hard to believe dyno numbers. That car ended up wrecked but from what I was able to gather it is a 997 MAF and was put together by a shop in Savannah.
Here is a link with pics on page three... https://rennlist.com/forums/944-turb...s-and-k27.html
Those are great numbers you are putting down and a/f curve looks good - does seem to be a little lean right at first. I would be very interested to see what you find in those reciepts. Do you know if you are running with the stock DME and KLR computers? I am sure they have chips in them but I am trying to remember if the other car I saw with this setup had some computer bits from the 997 as well.
More pics of the car in general would be well recieved - she looks like an excellent example!
that'd be RWHP...
Sure do appreciate all the great info. Just for reference I've got light headwork, aftermarket turbo with #8 hotside, 3" exhaust, Vitesse MAF and chips, tial 38mm and 55lb injectors and can't break 300 rwhp at 17lbs of boost - hence the curiosity about your setup.
i was told it had a custom DME/KLR tune. 38mm Tial WG, the hard pipes and MAF upgrade, turboXS RFL bov, when I have time i'm gonna have to take a look at the injectors...i'm used to the power now, i want more...oh and the guy i bought it from said i could turn the boost up 5 more pounds to 21, yet that would be pushing it and it seems bulletproof at 16 even though i normally run it at 10 but havent put it past 16...
i'm open to any response...i dont care...i'm still learning about all this mechanic stuff...i dont want to just get in my car and drive and not know whats going on like most people. and now, from what i hear or see for that matter...is a k26 cant support over 300whp which means that i need to keep debunking my motor to figure out what i have...some super gerbal running inside that turbo for all i know...so all comments are welcome
That definitely is not a 997 MAF, looks more like a 993 MAF with the quick screw lock connector. 997's use a snap on connector with a removable MAF sensor.
My .02 is that a k26 cannot... and will not... put down over 300 rwhp even maxxed out (WG clamped off). It simply can't flow enough air... (300 is seriously pushing the claims IMO).
The only way this can happen IMO is to add another power adder.. ie: nitrous, nitromethane,..etc...
Looking at the charts I will say it is a nice tune and the charts look like a k26 with boost falling off in the upper rpms. Except that they typically fall off more than that though. It doesn't look like the typical "maxxing out" since the boost is stable and not peaky.
If you are planning on running more boost you ought to think about fuel (qty and quality) also add a wideband and a knock counter. If you can, an EGT gauge.
The boost onset is late. That could be the controller or hotside though. Truthfully, it is not getting the most out of a k26 IMO. To me a k26 is for quick spool whereas this setup is as laggy as one of my 500hp turbos.
regardless it is a nice setup just needs tweaked. Which way to tweak it is a matter of preference.
