Aftermarket 944 Control arms. Retail pricing seems a bit off...
#181
I've spent too much time on these as it is. If anyone needs an old set of late offset control arms, I have set for dimensions.
C.
#183
These are the same style we have been using in NASCAR for years. They thread into the LCA and are super easy to replace. I did a bunch of testing on these for the engineering department at Michael Waltrip Racing.
#184
Please don't let the smart *** comments deter the serious effort some of you are making to get this project completed. Good luck and know that there are many interested in the final product.
#191
Just got off the phone with Howe Precision products. These guy can make a screw in ball joint to spec. Minimum order of 50 is required. Cool stuff. GREAT suggestion.
http://www.howeracing.com/Suspension...ints-Lower.htm
C.
C.
#192
I looked them up the howe precision ones at summit racing and they are around $70 - $90 each, and appear to be made for only for buicks, pontiacs, etc.
Summit also sells a Moog ball joint for 944's for $39 each: http://store.summitracing.com/partde...5&autoview=sku
However, when you click on the applications link, the site says these are for 83-85 944 convertibles only. ???
#193
C.
#195
That's cool. I didn't think the price was too bad, but was more concerned about fitment to our spindles. Maybe the pins can be dis-assembled from them and turned down to fit our spindles (assuming we can find some that are larger than 17mm).
