FS: bunch of (mostly) NA/early parts + TRADE OFFER
Rainman
Many of these parts were either taken off my 1985 944 during restoration or have been acquired over time as spares and such. However with an upcoming kitchen remodel it's time to clear some space out in the garage (and in my wallet).
Please make me some decent offers. Shipping depends largely on proximity and type of items, and packaging small and large items together will save money. Items are located in northern San Diego, CA (ZIP 92064).
If you need anything small that isn't listed I may have it so feel free to ask.
- stock NA front swaybar (23mm) + droplinks + aluminum outer loops + ~2yr old bushings $30
- good headlight motor + relay $75
- reference/speed sensors x3 $40 ea
- D/S and P/S taillight assemblies, no cracks $30 ea
- OEM waterpump blockoff plate with o-ring $5?
- NA Oil pressure sender/relief valve in unknown condition $20
- set of oil pan gasket bolt sleeves $depends how many
- rear lap seatbelts, beat up but functional x2 $10 ea
- early DME (Motronic .01) x3 $40 ea
- NA intake intact but ground down in most areas in a half-assed polishing attempt. good candidate for good polishing or powdercoating $25
- NA cruise control unit + computer, never figured out how to use it $20
- sunroof motor assemblies + relays x2, also one sunroof cable $25 ea, $10 for cable, $30 for a set
- OEM good used Bosch ignition coil w/ around 70,000 miles on it $40
- clutch fork + pin, may need new bearings or just a good cleaning $20
- black Porsche floor mats with red script in good shape, letters could use a cleaning; P/S front, P/S rear, and D/S rear only (no D/S front) $40
- 951 central locking switch, key logo in good shape $10
- NA catalyst heat shield $whatever
- set of front latches/hooks for sunroof $10 for a set of 3
- 3 clocks/2 oil pressure gauges (yellow on black face) $whatever
Also, I am looking for a complete turbo front end (header panel, fenders, nose panel and headlight covers) and would be willing to trade alot of this stuff for those items.
Don't forget your prices mate. I know you said to make an offer but I think it's part of the rules. Anywho, are you talking about Hella Vision Plus lenses or the bulbs that go into them?
Rainman
edited for prices. please negotiate if you think its too high.
the lights are a complete set, if you wanted to change your headlights you unscrew the entire old bulb assembly and screw these in. it is a bulb/lense combo.
Official Rennlist
Borat Impersonator
Borat Impersonator
what's the condition on the DME's?
Would one fit a 924S (ie plug size)? I'm thinking about picking one up to use as a base for Rberry's Maxtune/maxtronic setup. Thanks
Rainman
all the DMEs work perfectly, i've plugged them all in one by one onto my car and run them about 30 miles and never had any problems. i used them to play with the different fuel maps (one running rich, one running lean, one timing advanced, and stock). i can return them all to stock setting if you want.
they should plug into a 924S but you may want to check to see if your car has a 5v or 12v system, these are 12v computers.
