Finally put on my new rims! But how can I tell if there rubbing?
you need some 6mm or less slip on spacers- check ebay. Washers are not cut evenly enough to make the wheel sit flush w/ the hub do not do that its just not good.
What are stock tire sizes for a 924? Are they indeed 205/55/15 on front?
Either way, the car looks good. One of few 924's I find to be a nice car. The black is clean, and the bright wheels give it some pop. Not a bad combination!
I don't think that 205/55/15 are the stock tires, I believe there smaller. And thank you!
Rims look great! Definitely don't get washers - most of the force from the wheel to the hub is actually transmitted from the friction of the wheel surface being pushed by lug nuts against the hub. Obviously, the studs do transfer some force, but just adding washers would put a tremendous shear moment on the wheel studs. I think that paragon has spacers in stock if you're having trouble finding some
I got some spacers today, i'm putting them on in a minute or so. Thanks for the compliments guys. People told me I was insane becuase I liked them, lol.
The sewer lids don't fit the lines of a 944 very well. I personally don't care much for them as they have too much surface area (hubcapish).
However I think the round indicators and thinner profile of the 924 makes them work. Put together with the cleanliness of a well cared for car like yours, and you will get compliments as you see, as that example looks good.
ps. next time have the Crest center caps point to your valve stems. Just one of those OCD things. :P
Valve stems? I thought I was supposed to point the bottom of the center cap crest to the wheel lock. I'll change it, lol.
