Finally put on my new rims! But how can I tell if there rubbing?
Old 05-31-2008, 09:53 PM
Po924S
Po924S's Avatar
Default Finally put on my new rims! But how can I tell if there rubbing?
I finally got my new rims on. I love them! I know most people don't though, lol. How can I tell if they are rubbing? After I put them on, I took it around the block to see if they rubbed. I don't feel any vibration or anything, but from 0-30 miles per hour, I could hear something that sounds like it's rubbing. After 30 though, I don't hear anything. The tires are Front-205/55/16 and the rears are 225/50/16. It must be coming from the front, becuase I can shake the steering wheel a little, and the noise will be gone. The sound will come back though, if my wheels are pointed straight. How could they rub though? The front tires I had on before were 205/55/15. The only thing that changed, was that it went from 15, to 16. Anybuddy? Can I drive my car with the tires rubbing?
Old 05-31-2008, 09:59 PM
ELLSSUU
Geaux Tigers!
ELLSSUU's Avatar
Perhaps put some chalk on all surfaces that you think could rub. Drive around and see if it leaves any chalk marks on the tires.
Old 05-31-2008, 10:03 PM
Po924S
Po924S's Avatar
Thanks, i'll try it. Anybody else have some suggestions?
Old 05-31-2008, 10:04 PM
ELLSSUU
Geaux Tigers!
ELLSSUU's Avatar
BTW, looks great.
Old 05-31-2008, 10:08 PM
Po924S
Po924S's Avatar
BTW, looks great.
Thanks.
Old 05-31-2008, 10:41 PM
Spidey944
Spidey944's Avatar
Reaching with your hand, at the 12:00 position of the tire, reach over the tire and feel between the strut and the tire, see how much space there is bewteen the two. A common place to rub.
Old 05-31-2008, 10:45 PM
Po924S
Po924S's Avatar
I'll do that right know. What if it is rubbing, what do I do?
Old 05-31-2008, 10:54 PM
Po924S
Po924S's Avatar
Ok, I found the problem. The front rims are hitting the springs. Not by alot though. If I bought ten washers, would that do the job?
Also, with these new tires and rims, how will it effect handling, and performance?
Old 05-31-2008, 11:01 PM
bigdeano
bigdeano's Avatar
Smaller spring diameter or small spacer on the front hubs i think is the only way to fix that. Correct me if I'm wrong guys.
Old 05-31-2008, 11:09 PM
951_for_John
951_for_John's Avatar
Spacer would be the way to go, DO NOT USE WASHERS!
Looks good
Old 05-31-2008, 11:11 PM
Po924S
Po924S's Avatar
Originally Posted by 951_for_John
+1
Looks good
Why not washers? Were would I buy spacers. I don't need much to clear the spring.
Old 05-31-2008, 11:24 PM
WizPorsche944
WizPorsche944's Avatar
Wow They look really nice
Old 05-31-2008, 11:30 PM
Po924S
Po924S's Avatar
Really? Thank you!
Old 05-31-2008, 11:50 PM
rickb20
rickb20's Avatar
Default I've been wondering for a while now...
Is "anybuddy" an intentional misspelling to gain favor with other members?
Old 06-01-2008, 12:06 AM
Spidey944
Spidey944's Avatar
The Pep Boys here in Charlotte had them in stock. Not sure what size increments or bolt patterns they have though. You may also want to check with custom wheel shops. GL and you are welcome, it only took you 9 minutes to find out that I was right!
Quick Reply: Finally put on my new rims! But how can I tell if there rubbing?
