Transaxle spline line up
01-24-2008, 09:31 PM
How do you line the tranny splines up to t-tube splines?
01-24-2008, 09:44 PM
RainmanRennlist Member
01-24-2008, 09:45 PM
I can't get the collar to go on the t-tube. Any ideas?
01-24-2008, 09:49 PM
Are the set screws all the way out?
01-24-2008, 09:50 PM
Yes. the coupler will move on the trannys shaft but not onto the t-tube.
01-24-2008, 09:51 PM
Turn the shaft on the transmission side.
01-24-2008, 09:53 PM
I tried but it doesnt seem to want to slide on the t-tube.
01-25-2008, 08:56 AM
Did you tighten the transmission bolts that go to the bell housing already ?
if so loosen them up a bit and the coupler will go on , then retighten.
01-25-2008, 11:23 AM
you have to pull bolt all the way out.
01-25-2008, 11:55 AM
is the trans lined up properly on the TT - sometimes the pins dont align and the tranny gets "cocked" to the side alittle. Try loosening the four bolts alittle and wiggling everything around until it lines up.
i guess the trans arrived ok?
01-25-2008, 12:07 PM
It takes a few tries to get the angle just right. I had to get it to where it visually looked correct, then it would just bearly slide on (maybe half an inch). Then I moved it the trans slightly left or right and adjusted the height of the rear of the trans until it was easier to slide on.
01-25-2008, 12:33 PM
The bolt on the coupler is pulled out. It just slides up but doesn't go over. The shafts feel lined up.
01-25-2008, 03:48 PM
Quote:
Originally Posted by
turbopower
+1
01-26-2008, 12:59 AM
I finaly got it on. Damn that was wierd.
