Did any 85.5's have power / central door locks?
Hiya guys, I'm looking to add power locks to my 85.5 but I can't find the factory wiring under the dash near the steering column for the control unit or under the radio in the console for the control switch. I know I would need to change out the door harnesses which is no big deal but I'm not willing to rewire the main harness. Is there something I'm missing? A quick look through my original 85.5 owner's manual makes no mention of power locks, did this come along in '86? Cheers.
Rainman
I just added aftermarket locks...you just need a 2-position switch (I recycled my sunroof switch) and a power source (tapped off the cigarette lighter supply).
Haven't had any issues since.
I don't mind drilling to mount the solenoids if necessary I just want to do it with the factory wiring I can't seem to find on my 85.5...
Yeah, I have seen several '86's with factory pdl but have yet to see an '85.5 with a factory install. At this point I'm thinking there was never such animal.
My 86 didn't have central locking. I added aftermarket lock solenoids. don't need a central switch, when you lock or unlock one, the other one automatically does the same thing. I also added a small flashing LED in the door right next to the lock **** on each door that is triggered by the locked position power to make it flash when the doors are locked. Only had to pull a couple new wires to each door. Did the whole thing in an afternoon.
^^ that is what I did, the problem was that the aftermarket 5 wire solenoids had double the travel of the stock mechanism. Whenever they slipped due to this, they could get stuck in a feedback loop where one lock would trigger the other, which would then reverse it. The locks would continue to cycle on their own when it got into this mode.
I inadvertantly got caught up in this recently, I am swapping my 85.5 factory harness for a 86 harness. The connections for the doors are completely different, and the 86 harness has connections for power door locks, so unless you plan on changing the factory harness completely I would rule the factory stuff out.
Mark
Mark
