Oil Cooler pics
Oil Cooler pics
There was a discussion last week about how to mount an aftermarket cooler and how to run the lines. Here's a few pics of mine. Everything came from BAT in Florida, including the sandwich adapter with thermostat. It's a 16row by 235mm cooler. If I were to do it again I would probably get a slightly shorter, like 12 or 14 row cooler, it would be easier to get into the available space.
Cheers
Randy
http://forums.rennlist.com/upload/oil_cooler1.jpg
http://forums.rennlist.com/upload/oil_cooler2.jpg
http://forums.rennlist.com/upload/oil_cooler3.jpg
http://forums.rennlist.com/upload/oil_cooler4.jpg
http://forums.rennlist.com/upload/oil_cooler5.jpg
Cheers
Randy
Last edited by AlpharettaRK; 10-05-2007 at 11:43 PM. Reason: Fixed the picture links
I've always wanted to add a 2nd OEM cooler on the driver-side. There's even a opening for it, just remove the block-off plate and use the air shroud. Your install looks great.
Oil presure was unchanged, it runs between 3 & 4 bar on the track, which is almost never below 5,000 RPM.
Works great - no issues whatsoever. I put loctite on the hollow bolt that goes through the adapter plate so it does not back out when I change the filter.
It wasn't a kit, but here's the list of stuff. It all came from B.A.T. in Florida except for the grille in the foglight area which was stuff bought at a hardware store. Joonas - with the worthless nature of the US $ right now they should be able to fix you up right!
Cheers
Randy
AF16F22 16 Row 235mm cooler 141.00
2 M22AN10 Adapters 11.00
SP1FT Sandwich Adapter 89.50
ABKT-235 Bracket 18.25
2 DS1/2 Seals 1.20
6 ft SS Braided hose 39.00
2 T45-10 Fittings 37.50
2 T150-10 Fittings 49.00
A52Fan-PL Pull Fan 69.50
Total 455.95
Cheers
Randy
2 DS1/2 Seals 1.20
Total 455.95
Randy, thank you for reply! Good info.
For me the sandwich plate seemed suspicious.
What about your oil temperature gaugage project? How are the temps and where did you get the oil temperature sensor and gaugage?
