project: turbocharging 944 N/A the proper way
#467
It's completely blank
http://www.daskeyboard.com/daskeyboard-4-ultimate/
The names and words are strange if you try to understand it trough english because it's different.
For instance we don't have Y, we use J instead for same vocal letter. Your J is Đ here but we don't use Đ in our language, croatians, serbians and bosnians do however. And we have grammatical number dual, which blows minds of some people. (it only exist in Scottish, Slovenian, and Serbian)
English is easy so it's probably hardest to learn other languages if your base is english.
#468
Few recent photos.
New BS bushing bearings.
Turbo oil outlet on 2.7 block
968 tensioner on 2.7 block, home made longer studs
diy Rod bolt stretch gauge V1
V2
New arp's this time correct 1.6 lenght
Out of the box lenght variation
Whoops. Little 1.5mm mistake...
... worth $180.
Testing oil dynamics
V2
... worth $180.
#470
I have some problems with oil pump(s), can't open them and stripped at least one of two allen bolts on each. I have pumps at machine shop atm.
Otherwise this project is at this moment at the back burner as it's less than 3 weeks till main vacations and I work on boat almost every day. Have to assemble two stroke 90 hp Johnson V4 60° and get it ready and registered in 3 weeks.
This is the boat's engine condition now:
#471
Otherwise this project is at this moment at the back burner as it's less than 3 weeks till main vacations and I work on boat almost every day. Have to assemble two stroke V4 and get it ready and registered in 3 weeks.
Cool, and everyone needs to get the stuff before vacation.
#472
Nothing special, just want to open two I have and make sure the one I put on is perfectly good.
I have to take some time and put engine together slowly and easy, I rushed last time and ruined nose crank bearing. Expensive stupid mistake.
#474
Etec 3.2L 300hp direct injection two stroke would fit in easily and probably fly in 944
Btw: if anyone thinks porsche parts are expensive check out brp prices.
#475
Totally unrelated but it is what it is Posted these on another forum but thought I could share here too.
Built the 60° Loop charged 90hp V4 Johnson, it fired yesterday and it sounds mean. T minus 5 days till vacation..
#477
Previous owner of engine core must have discarded it.
T
#478
#479
Recieved final piece of engine management today
J&S 4 channel interceptor capable of individual cylinder retarding up to 20 deg.
