Replaced oil pan gasket now car won't start!!!!! help
Old 07-16-2007, 02:09 AM
Yummybud924
Yummybud924's Avatar
Default Replaced oil pan gasket now car won't start!!!!! help
I replaced my oil pan gasket, oil pump and had to take off all the belts, support the engine from above, take down the crossmember and steering assembly.
now I put everything back together and go to crank it, crank crank crank and nothing, doesn't even sound like it wants to start at all.
I replaced my belts last year and it started fine. I'm pretty much 100% sure that my belt timing is fine. I used a crank lock and made sure all marks lined up and I turned the engine over by hand a few times and it turned fine and marks still matched up.
now all I can think off is that when I first removed teh crossmember the engine kind off went down low and I thought maybe some wire or something got ripped? not likely but I can't think of anything.
I went looking everywhere for a loose connection or something I missed and can't find anything.
another thing I did was remove teh rear shield from the alternator and I accidently splashed water on the alternator but would that have anything to do with it not starting?
also I have a big water leak from behind my dah I found out it was water leaking from the heater unit on the centre console when I spray water down the winshield so I thought maybe something got wet and damaged?
this is really frustrating, I wasn't expecting a no start after all this hard work.
before I took the oil pan and everything out the car would start and run great.
any idea of what the most likely cause is? I'm not too good at finding a no start problem already giving up hope lol.
other than checking for any loose connections or anything obvious I've just cranked it and yelled at it "son of bitch why won't you start"
the neighbours probably think I'm crazy.
Old 07-16-2007, 03:34 AM
sillbeer
sillbeer's Avatar
Id check the speed and reference sensors. they are on the bellhousing under the brake master cylinder. Id say check the AFM but when mine was disconnected it would crank and sputter but wouldnt actually start.
Old 07-16-2007, 04:08 AM
Yummybud924
how would I check them? just check to see if they are loose?
I checked all around and everything seemed tight and connected.
I thought when jacking up the engine and lowering it and having it supported from above something must have been screwed up.
Old 07-16-2007, 04:27 AM
sillbeer
sillbeer's Avatar
yea, make sure the connections arent loose or anything like that. Ive heard of sensors randomly failing but, i dunno. Also check and make sure the obvious stuff is good, like the fuel pump, coil wire, etc...
Old 07-16-2007, 04:55 AM
Yummybud924
I wouldn't think anything like the fuel pump would just fail after being left for 2 weeks on jack stands.
the car was running great before I removed everything. I looked around and didn't see anything loose.
Old 07-16-2007, 05:27 AM
sillbeer
sillbeer's Avatar
I dunno sir...hard to troubleguess over the net =)
Old 07-16-2007, 07:55 AM
Yabo
Yabo's Avatar
find out if it's spark or fuel
Old 07-16-2007, 08:01 AM
931guru
931guru's Avatar
Check your compression.
Old 07-16-2007, 11:36 AM
Yummybud924
I can only try simple things like maybe taking the spark plug out and seeing if it sparks.
other than that I don't really have the skill to start testing the electric system with multimeters and oscilloscopes lol, hope it's something not too difficult to find.
Old 07-16-2007, 02:33 PM
jwade944
jwade944's Avatar
DME Relay?
Old 07-16-2007, 03:11 PM
924RACR
924RACR's Avatar
You may find you now have time to develop that skill...
Old 07-16-2007, 03:15 PM
sillbeer
sillbeer's Avatar
if you have a spare GOOD spark plug laying around you can use that, plug it in and lay it against something metal. when you turn the key on, listen for the fuel pump to prime
Old 07-16-2007, 03:57 PM
2BWise
2BWise's Avatar
Multimeters are easy to use and most of the information to test many of the parts is already available on line.
Old 07-16-2007, 07:05 PM
GodSpeed
Nissan Rulez
GodSpeed's Avatar
Does the tach bounce while your cranking the engine?
Old 07-16-2007, 08:48 PM
xsboost90
xsboost90's Avatar
sounds like a ref sensor got tugged on- check the tach to see if its boucing as described. Have someone crank and someone else put their hand on the fuel pump to see if its priming. If neither, sounds like Ref sensors or dme relay is bad/ bad connection.
Quick Reply: Replaced oil pan gasket now car won't start!!!!! help
