foglights not working
both foglights in my 87 944 arent working. the fuse was good, and the bulbs looked fine. any ideas for how i should fix this?
Not Special
Along Dan's line of reasoning, unplug them, make sure the plugs look clean, and plug 'em in. If you've got a voltmeter, test the sockets with the light switch on; do you get a reading?
Do the orange side/marker lights work when the headlights are on? After repairing the front valance the bodyshop switched the wiring for side/marker lights and the fogs on mine.
M
M
Originally Posted by PeteL
Someone I know had the same problem, will not mention names, but when he turned off the high beams, the fogs worked again. I'm just sayin'.....
Got Nothin'
Originally Posted by bloodraven
I'm guessing this guys name is Pete?
Brilliant!! Unfortunately, "Pete" sent a plea for help from Rennlist before he found the problem.
