something like Guards red is probably extremely similar to Chevy's Victory Red, since it is a solid color. But you should be able to go to a Napa or some other autoparts place, one of them usually has a low-end brand of PPG or DuPont paint available
all reds , yellow , and orange ,cost more than say a color like white . its becouse of the pigments used . all reds in base coat clear coat cost about the same in the 125. daller range per qt. i use glasurit in my shop is what porsche uses also vw , audi, and some benz,es . if you like your car and you want it to look good, then dont cheep out . you could go with a single stage paint gob and save some money , or cheeper would be single stage acrylic enamel, or even cheeper alkyd enamel , but i would only use enamels on a dump truck , no i would not even use it on a dump truck . my be a dumpster. over the years porsche has changed the shade of guards red 16 times ,like in 1996 the color code was L80k in 2007 its L84a guards red is just a name . you need to order the color by its color # not its name. if you have questions you would like to ask me about refinishing you can email me on private messages
I used PPG DCC acrylic urethane single stage (no clear coat) with the PPG DCX61 high solids hardener, and PPG DT870 reducer. Matches perfectly, sprays nicely and works as promised w/ proper flash times and everything.
I found out that rustoleums red paint is identical to porsches, so yeah, lol umm if you are just doing touch up , it works good! And it stops rust!! Its a win win situation.
if you just painting the out side of the car , no jams . than 3 qts of base should do and one gal. of clear . red is transparent so it takes more coats of base to cover . you should use a sealer first , you would need 2 qts of sealer to spray one wet coat over the hole car .matterial cost for sealer,base,and clear will run you about 500 to 600 dollars.
why clear? Porsche did not put clear on at the factory on gaurd's red. Basically, you can get shinier final results w/o clear coat.
how do you figure? You can get some good single stage eurethane paints now, but they will cost you more than if you go w/ a good clear coat, which is shinier, lasts longer, and has more uv protection against fading.
If you want a "cheap" paint try Matrix or Valspar basecoat. Just look in the yellow pages for body shop supplies and call around. Don't order paint over the internet..hazmat shipping is expensive. I would suggest avoiding enamels and the like as once you use it in my opinion the car is ruined if you want to put a decent paint job on in the future. Enamels are very unstable and will cause problems later if you go back with base/clear. Good single stage paints don't offer much savings over base/clear and most shops don't use them any more. If you have any dust nibs or sags base/clear is much easier to work with. Rustoleum is oil based and will not be compatible at all with automotive paint...again, it will affect the products you can use in the future.
I painted my race car guards red using a cheap NAPA crossfire brand single stage paint. Worked fine for a race car, but I learned that I will never paint a street car myself. Just too easy to screw it up. Race's car on the other hand... I have no probem painting.
Sand
Good luck!
and how much did that cost you total for the paint supplies?
