Smoke?
#31
Wax On, Wax Off
Originally Posted by ATL944
My dad got a call from the mechanic and it turns out that I have hydraulic lines that are busted and a coolant leak. ![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
I knew that smell... and the only hydraulic lines are in: brakes and clutch
#32
Originally Posted by Porschephile 924
PORSCHEPHILE 924 FTW!
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
#33
Wax On, Wax Off
not too much. I'm guessing it's the clutch hydraulic line, which is about $36.00, or if it's the brake line, buy a set of stainless brake lines... $65.00 http://www.paragon-products.com/product_p/por1200.htm
http://www.paragon-products.com/prod...7.721.189a.htm <--clutch line
#37
Wax On, Wax Off
http://clarks-garage.com/shop-manual/clutch-02.htm there's how to get to the slave for the clutch line on bottom
clutch line on top is at the end of the arrow in this pic. unbolt, replace, bleed, and be done. then worry about fixing the other leaks... coolant leaks are generally easy to fix.
#41
Addic
agreed, my last PO has a receipt in my binder and the cam housing was leaking (rare, i know) he paid $27 in parts, and about $500 in labor. I'de go dig up the receipt, but its not important, its a $500+ bill for $15 gasket. no way i'de have a 944 and pay a mechanic, or any other car for that matter
#43
ATL, if you do decide to let Kerry take care if it, I can assure you that he knows these cars inside and out, I trusted him with all the stuff I couldnt handle in my 944S and I've always had pleasure doing business with him. He's very fair and honest. Even though its a NAPA service center, his Porsche techs used to work International Performance Center who did top quality work at fair prices.
hope you get it back on the road soon!
#45
Rainman
with Rennlist and a wrench, you can do ANYTHING.
Anyways...I like how the shop charges almost 2k for $100 in parts and maybe 3 hours in labor (including lunch).
