New Here
I just registered and thought I would say hi and ask for some advice. I am currently thinking about a '88 944 na with 130k that a friend of my son is selling. I have not looked at the car yet, but my son says it looks good. He recently put a new head and a bunch of other work into the car. He told me that the car does not move because it needs a trans, but I think it may be the clutch. The trans shifts fine with the engine running but something clunks and bangs when the clutch is released. He only wants $1200 for the car so I think it is worth putting a little work into since the rest of the car is in pretty decent shape. Any thoughts or advice would be welcomed.
If the pinion and ring gear are gone in the trans (which is the typical mode of failure), it will still shift with the clutch depressed but will sound horrible once you let the clutch out and try to move it. It is possible it needs a new trans. A quick way to check this is to drain the fluid and look for chunks of metal. It could be the clutch, *maybe*. If it has 130K and the clutch hasn't been replace, it is possible. But wish for it to be the transmission. It is easier to replace the transmission in these cars than it is to do the clutch job, and generally is cheaper too.
Clutch requires more then "a little work"
New head might mean he didnt change the Timing Belt on time.
$1200 is a good buy, however fixing these cars does add up fast. Also note that the resell on a N/A 944 rarely goes over $5k.
Do you plan to to buy as a daily driver or for fun?
Ultimately I'd ask... do you have another 3800 to burn if you purchased the car?
flash - welcome to Rennlist!
The clunking sound may very well be the clutch - the rubber centered clutch hub deteriorates over time. The bad news - it is a very labor intensive repair job. The good news: it's not as bad as replacing a tranny!
My bro-in-law just sold his running 944 to a fellow Rennlister out in Erie PA. While he needed a clutch (and a tb, and an H2O pump), he sold it for a good price...
You're in North NJ - I'd like to invite you to the Northern NJ PCA region - come on out next Wednesday (Jan 10th) to our monthly meeting at the Villa on Rt 46 East in Mountain Lakes. (Start time is 8pm). We will be showing some PCA-related videos - some archival footage, some newer stuff. It may be a great intro for you to the club. Club membership adds a lot more depth to Porsche ownership.
Again, Welcome!
- Zoltan.
Again, Welcome!
- Zoltan.
Tifosman - But wish for it to be the transmission. It is easier to replace the transmission in these cars than it is to do the clutch job, and generally is cheaper too.
Z-man - The clunking sound may very well be the clutch - the rubber centered clutch hub deteriorates over time. The bad news - it is a very labor intensive repair job. The good news: it's not as bad as replacing a tranny!
LOL.....umm guys....can we have some consistency?
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
LOL.....umm guys....can we have some consistency?![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
But whether it's the clutch or the tranny, it ain't pretty...
-Z
Wax On, Wax Off
FWIW, I had picked up a transmission for a 944 for $300.00, used of course... unfortunately, it wasn't the problem and made me look like an ***, but it was returned...
So, if you can find a used 944 transaxle for cheap, you'll be golden.
I don't think the 88s had rubber centred clutches. The clanging is probably the r&p in the tranny. Its terminal. The Pinion needs a preload adustment every 60 K and its the reason for transmission failure and is very common. It costs about 800 bucks to get that work done. At this point I'd pay the best price you can negotiate minus $1200 for a tranny change. Great cars once you get them right.
-Z
If you have basic tools, a jack, and a helper, you can remove and replace the trans in less than 3 hours. Do a few of them and you can drop that time drastically.
I think its the trans r&p based on the limited knowlege we have. But you know how it goes when you attempt to diagnose problems over the interweb.
Yup. Tranny is a snap and much easier then the clutch. You can get a nice used NA tranny all day long for less then $500. Especially in NJ.
welcome to rennlist- 88 = best compression of any of the n/a's!!! Jack the rear end up and try turning the wheels or holding one side and turning the other side. IF it sounds like a box full of marbles then you prob need a trans. Could be a blown CV joint really. Usually when the rubber center goes out, the car still moves, but it clangs real good every time you let the clutch out since the rubber is gone. I would personally check and see if it has the stock clutch still- if it does, even if its good- its time for a replacement.
