NA maf - great results, and a question?
#121
Administrator - "Tyson"
Along with the Ford EDIS, a full wasted spark system and 100% user tunable. Complete system can be built for under $1,000
Hey guys,take a look at this
"Peak power remaned exactly the same, albeit slightly higher in the rev range, while peak torque was slightly up at 147lb/ft @ 4727rpm against 145lb/ft @ 4760rpm."
Also need to remember their two base line runs were 151bhp and 149bhp without any changes between the two runs.
#122
Small Business Partner
So Rogue, have you read this thread? To your knowledge, is it possible to just hook up a Ford Contour MAF to our cars, and have it run correctly? Meaning, nothing would have to be done to the DME.... maybe just some adjusting of the FQS or maybe adjusting the fuel pressure at the regulator to get the correct mixture?
Can you hook up a Ford MAF and run correctly? The short answer is no, at least not without some issues.
I explained some of the issues here:
Link
-Rogue
