elevation horsepower loss
Wax On, Wax Off
Well, using my Gtech pro SS, I did a run last time in California, and one here... and a Dynojet in Mansfield, Ohio...944fest last year (2005)
Well, there was a very significant loss in horsepower a mile above sea level...
Test car: 1987 924S (N/A)
Sea level (approx. 30 feet above sea level): 138 HP, 129 ft-lbs... (approx.)
Mansfield Ohio (approx 1242 feet above sea level): 123.6 hp, 122 ft-lbs
Denver, Colorado (5280 feet above sea level): 98 hp, 94 ft-lbs
I was shocked at how low the HP rating was up here... the tests with the Gtech were run multiple times... and I did test it on a drag strip (here) so I know the times were accurate.
I can post the graphs later if anyone wants to see what the Gtech pulled...
thats why the computer is adjustable- to compensate for elevation changes. Where was your car purchased? it could prob. be adjusted out on the ecm back to normal.
Theres less power because the air is thinner = less air getting into the engine.
comparing G-tech number to dyno number is kind of wackly. 138 hp is alot for an NA, too much considering the 129lbs of torque. 123 is what I would expect from an 87 with a cat. Phx is about 1200 feet so this matches up. 98 hp at 5200? Well again was that a g-tech run. I would not trust that. Also most dyno's are calibrated to correct runs to seal level and SAE temp so on dyno the corrected numbers SHOULD be the same at any temp and elevation. At least that is the idea for corrected numbers.
Wax On, Wax Off
