Can we make a list of coolants that are safe?
I always have a problem finding coolant that specifically says it is phosphate free. I know some people say it's fine to use coolant with phosphates as long as you use distilled water, but I like to be on the safe side. There are also a number of coolants that say they are safe for all engines, but actually do have phosphates in them. The manual also says that coolant should be silicate free, I don't know if I've ever seen silicate free coolant on the shelves at the big auto stores. I thought it might be helpful to have a list of which coolants are good, and maybe where to get them (I know Mercedes and VW have some coolants that are maybe a bit different).
Addic
check ingrediants on the back, they will state there if it has phosphates or silcates.
i used prestone 50/50 new formula for all engines. it didnt list phosphates or silicates, and seems to be keeping the engine by the first mark
Captain Obvious
Super User
Super User
Originally Posted by bloodraven
I don't use coolant....water wetter and distilled water. easy as pie...
That's because you don't live where the temperature falls way bellow freezing. If it ever does you'll be in for a suprise!
Ill be using NPG+ Waterless Coolant in my car. Boils at nearly 400F, so it cuts down on hot spots, and theres no cooling system pressure, maybe just 1 or 2PSI. Of course its $32.50/gallon, but oh well
Captain Obvious
Super User
Super User
Originally Posted by theedge
Ill be using NPG+ Waterless Coolant in my car. Boils at nearly 400F, so it cuts down on hot spots, and theres no cooling system pressure, maybe just 1 or 2PSI. Of course its $32.50/gallon, but oh well ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
Originally Posted by yieldsign2
So, with a phosphate free antifreeze you can use tapwater?
Here is another example: My sister and brother-in-law live out in a rural suburb east of Cleveland and have a well for potable water. They use a good quality water softener and filter. The water is corrosive enough from dissolved minerals that the anodized finish boils off their cooking pots after a year or so right to the water line. Wanna put that in your cooling system?
There is nothing in any coolant that will actively dissolve or corrode your motor, it is generally the combination of the water that you use that takes care of that for you.
Also, you MUST NOT run straight water. You have to use at least something like Water Wetter since it is a surficant and a lubricant. See the thread linked to in the post a few above this one
Hey Man
Call me cautious but any product that has been around since 1990 and hasn't become mainstream in 15 years would get me looking closer at the reasons why. At least it it doesn't pollute or kill pets.
