Anti-Freeze
Anti-Freeze
Before you flush your 944/951 and add the WRONG STUFF!
I have researched the threads asked the experts ect.
I know that there are a lot of brands out there and I used "Petosin" the VW coolant when I could buy it.
I have looked and looked and finally found what can go in the Water cooled Porsche 944/951.
http://www.valvoline.com/pages/produ...asp?product=11
Hey Man
Beware: It cost money to to add the wrong stuff to your Porsche 944/951 water cooled system.
NO the right stuff is sold buy your factory Porsche dealer. It is known as "Petosin" German Anti-Freeze.
However this is equal. It has yet to recieve "Porsche approval" but is recommended for water colled Porsches. I have talked to my wrench, googled threads, Searched threads. The only stuff that I have found that is at NAPA, Auto Zone, ect that meets the no phosphate no silicate rule is this stuff.
Do I sell the stuff No
Hey Man
...http://www.valvoline.com/pages/produ...asp?product=11
I made the mistake of buying something Phosphate Free in large print, and then seeing in tiny print "Propylene Glycol"
I use VW / Audi original coolant G12plus (latest, it substitutes G11 and G12). It's the ultimate performacne and fair price. It is based on ethylene glycol with lots of additives to extend life. This coolant doesn't need to be changed. It's the lifetime coolant. You change and forget it. Ask Your nearest VW/Audi dealer for this stuff. Here in Poland it costs about $12 for 1,5 liter bottle (concentrated). You need 3 bottles for a change.
PS. Dont forget to drain Your block, not only the radiator.
Mix of G11 (g01100) and G12 (g01200) is not allowed. G12+ can be mixed with both G11 and G12. G12+ is purple. Here in Poland G11 and G12 have been withdrawn from the market. You can only buy G12+.
Take a look at the head pictures in this thread if you want to see why it is important to use an aluminum-compatible antifreeze.
OK, from the research I have done over the past several years:
- Sodium Phosphate, which is the "phosphate" that you speak of, is not corrosive. It is actually added to coolant as a corrosion inhibitor. It is not corrosive to iron, it is not corrosive to aluminum, it is not even corrosive to Reynolds aluminum. However, it also is not the best corrosion inhibitor for aluminum blocks, which is why "aluminum safe" coolant generally does not have phosphate in it.
- Some anti corrosion additives can possibly cause mineral dropout. This is when mineral in the water "drop out" of solution and cause deposits. This can appear as reddish discoloration in the coolant passages, or whitish scale, etc. European and Asian manufacturers realize this and spec certain coolant for their vehicles because they cannot guarantee water in the rest of the world will not be crap. CYA in other word. Because of this fact, you should always avoid using tap water, especially if it is well water. G-d only knows what is in well water. As a matter of fact in northern area where roads are salted in the winter, that salt can and does make its way into ground water and thereby wells. Do also note the flouride added to municipal water is corrosive, and that other minerals found in municipal water will drop out of solution quite easily in aluminum block engines. It is very likely that if you dump your coolant into a bucket and see sediment in the bottom of the bucket that this is minerals that have dropped out of the water, not you engine coming apart because of the coolant you used.
- Running straight water is bad. Coolant is added to raise the boiling point, but it is also added as a lubricant. In addition, coolant has surficants in it, which make water wetter (yeah, that is why that stuff is called that) thereby causing the mixture to have better contact with the engine internal passaged. This is important not only for better heat transfer, but also to prevent cavitation, which will cause errosion. Errosion and corrosion are not the same thing, but look similar.
- You MUST change your coolant regularly. It does wear out and lose its effectiveness. 2 years is the standard rule of thumb.
- It doesn't appear you can judge a coolant by its color anymore. SAE had standards back in the day but these appear to have flown out the window.
All of that said, and I do have much more, if it is same price or even a little bit more expensive and it gives you peice of mind, by all means use the stuff people say is the "correct" stuff. On the other hand, if your mechanic added the reviled green stuff, not need to rush out and change it right away. It WILL NOT actively eat away your motor.
