Cutting the Cross-Over pipe with a Sawsall
Just wondered if anyone else has tried this. I am getting pretty tired of stripping/drilling bolts. And since I don't really plan on keeping the old cross-over any way, I was thinking about cutting it up to make the removal of it easier and faster. Any comments, suggestions?
Just a thought on this one. A good friend of mine was burned severly while using a saws-all under his S10. Hit gas line .sparks from motor ignited the gas=a lot of pain!!! Think twice on this before doing it.. Good luck , FRED
I have had that thought every time I have to remove the cross over pipe. I wish I can do it just once and demolish one just to defy the idiotic German engineers who designed the unit.
well it is hard to finegal out of there once the bolts are loose in one piece. If you do cut it and ever plan on rewelding it or flanging it, draw a line down the pipe before you cut it and cut through that line so you can line things back up once its off the car.
Wax On, Wax Off
I'm lookin at the SFR stage II header with the 3 peice crossover built in for when I get a turbo... that thing's nifty... but extremely expensive, so it'll be a while...
The yellow circles show the two bolts that I am have trouble getting to. Right now I am using socket with a U joint, but I am not really getting all the torque I need to get them loose. The lines shows where I was considering cutting it. This would give me better access from directly underneath. I didn't think this thing had much value based on what I have seen them selling for on EBay lately. Maybe I will take some pictures when I cut it up for those of you that despise this thing as much as I do!
