Early porsche 944 wont start..HELP!!
hey every 1 thanks for lookin at my post im new here to rennlist but not to porsches. ok heres the problem....my early 944 wont start. i have spark and i have feul at the injectors. perfect compression and perfect feul pressure. checked everything AFM TPS timing is perfect ignition is ok checked the speed and refrence sensors there ok. completly lost on what to try next. i live right by a well known porsche place Phils automotive and they have been helping me but are lost too. please any help would be much appreciated! thanks!!!!!
Bryan
Bryan
Defending the Border
Rest In Peace
Rest In Peace
Wow, good one. Electrical connection? TriedCalrk's Garage yet?
Check out TS-01, Engine, under Troubleshooting.
lol im checkin all elecrical now. but yes ive been threw everything on clarks but they dont have anything on if u do have spark and fuel. i have the alarm but i found out how to bypass it threw clarks but that didnt help none. still stuck thanks guys for ne help!!!!!!
Bryan
Bryan
it just cranks and cranks and cranks some more...every once in awhile when i release the key is may sputter but only once in awhile...no weird sounds or nething. the only things i havent replaced yet are the cap and ignition switch. but i heard i wouldnt have spark if either of them r going bad. should be gettin them in the next couple of days. i love this car and dont want to get rid of it. to much work ive put into it. shes fast when it starts. lol thanks again every1
Bryan
Bryan
Big thirst, Sore Thumbs
Napoleon
Napoleon
A: Check your F'ing grounds.
That's not it, but do it anyways.
B: Replace your coil. You can get a weak spark and the car won't start.
Before anyone want's to say "No way it can't be the coil" Been there done that. I froze my *** off on the Canadian Border and Chris walked something ike 800 miles back and forth listening to advice like "It can't be the coil" business.
yes i have pulled the whole rail off and watch each injector fire. ive done engine grounds even checked to make sure with a wire from the battery ground. i tested the coil and it all matched up fine with the specs. but will look into gettin one. thanks!
Bryan
Bryan
Napoleon
Napoleon
Hey I'm up there next week. Busy Thursday and Friday.
Maybe you can show e what's broken on your car now.
If you see the injectors spraying fuel, then I'd look a lot harder at the ignition side. If you are getting spark then my guess is that it's a weak one. I would expect that a healthy spark with erroneous timing would at least produce backfires. Have you checked the cam belt to see if things are lined up properly?
