Brake Job Recommendation/Help, Please
4th Gear
I need to replace rotors and pads on my late '85 944. What would you recommend for occasional street driving? Looking to aftermarket ones, as the OE seem to be too expensive at this point.
Any suggestion on where to install them in lower Westchester, NY at a reasonable price? The mechanic said 5 hours to do the job on both front and rear. Thanks!
Wax On, Wax Off
well, at Pelican Parts (www.pelicanparts.com) they have some great deals... you can buy a set of pads (fronts and rears) for about $60.00 for the Mintex brakes... as for rotors, they're pricey. good luck finding a deal on those.
Also, welcome!
Also, welcome!
I can't offer mechanic help in NY, but the OEM (but non-Porsche) rotors and MetalMaster pads can be had pretty reasonably from sponsors here. I have bought from most, but my usual is Paragon Products. I always have good service, selection, and pricing.
It's not a tough job for the do-it-yourselfer. A Haynes manual will get you through it. Better yet, do it with a friend that has done the job before and you will be your own permanent brake wrencher.
Pads and rotors are wear items. By the way, I only replace rotors due to minimum thickness. Otherwise, I pop pads in and out like they are going out of style. I have never needed to turn/cut a rotor on these cars yet.
Wax On, Wax Off
Also, if things rust where you are, DEFINATELY pick up a brake hardware set... about $60.00 per axle, but you'll be kicking yourself in the head if they're rusted together, and you have to re-use them because they're so rusty...
4th Gear
Please excuse my obvious questions. Thanks much.
Gene
go on like paragon-products or pelican or somewhere and just buy some stock rotors- most racers use stock rotors unless they have crazy brakes since they work well and are cheap- and yes i love metalmaster pad they are killer, just get some metalmaster stock replacement not carbon fiber or anything that will have to heat up before they work.
Wax On, Wax Off
zimmerman rotors are fine. no need to go big dollar unless you're going the cross-drilled route. It's just steel... The brake hardware is the springs, pins, and clips that hold the pads into the caliper.
these things http://www.pelicanparts.com/catalog/...stener_kit.jpg
at Pelican, it's the brake pad retainer clips.
4th Gear
Thanks all for your help with this. I went with Zimmermann rotors and PBR Metal Master pads from Vertex. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Is 5 hours a reasonable time for a mechanic to install them?
I can change pads all the pads in less than 1 hour. Roots take bit longer, but maybe 2 hrs -2.5.
5 hrs seems way too long for a shop. About right for a novice.
