The end of the blacky- COMPRESSION TEST RESULTS :(
Old 03-06-2005, 02:02 AM
Gator_86_951
Spell Checker
Gator_86_951's Avatar
Dude, i just listened to the video again, that really doesn't sound good. I think you broke something, mechanical.
Then you didn't float a valve. Your oil pump might have crapped the bed and you may have spun a bearing. That sounds is crazy Man. 944 motors can be had for not so expensive. I wouldn't sweat it.
Old 03-06-2005, 02:06 AM
Rock
Lazer Beam Shooter
Rock's Avatar
Old 03-06-2005, 02:08 AM
Rock
Lazer Beam Shooter
Rock's Avatar
it was running bad before this, i thought it was just a vacuum leak or maybe the FPR, nothing terrible...
It just didnt accelerate as fast as it used to... like it just felt flat, thats all
Old 03-06-2005, 02:09 AM
Rock
Lazer Beam Shooter
Rock's Avatar
Did it backfire? Maybe oil is interfering with the gas and the fuel combusting which caused the smoke? Then maybe too much oil got in and caused it to burn too much oil and back fire?
Could it be the air/oil seperator tube clogged up?
Old 03-06-2005, 02:10 AM
Gator_86_951
Spell Checker
Did you check the compression yet? That pop is what is crazy. Are you sure it wasn't back fire?
Old 03-06-2005, 02:12 AM
Gator_86_951
Spell Checker
It could be back fire too. I thought you had eliminated it. YOu might just have a badly blow gasket. Check the compression.
Old 03-06-2005, 02:13 AM
Rock
Lazer Beam Shooter
Rock's Avatar
i dont have a compression tester i guess ill just let it sit until tomorrow
Old 03-06-2005, 02:14 AM
Gator_86_951
Spell Checker
Check the compression and drain the oil. Check the oil for metal and just go on from there. Doing a gasket on your car would be pretty easy since it isn't a turbo.
Old 03-06-2005, 02:15 AM
Rock
Lazer Beam Shooter
Rock's Avatar
it just got a new gasket in november
Old 03-06-2005, 02:17 AM
Gator_86_951
Spell Checker
Don't worry about it. I am sure it will be fine. If it totally blew up you can always get another engine for pretty cheap.
Old 03-06-2005, 02:20 AM
Rock
Lazer Beam Shooter
Rock's Avatar
it sounded like a gun went off
Old 03-06-2005, 02:21 AM
Macfreak007
Macfreak007's Avatar
yeah, sounds like new motor time to me.... everything gator says is the way to go. Cut the oil filter open as well when you drain the oil. Gold material means a spun rod bearing....
good luck!
sucks!
Old 03-06-2005, 02:23 AM
Rock
Lazer Beam Shooter
Rock's Avatar
damn
the smoke was UNBELIEVEABLE i cant stress that enough.
That video does not do the smoke justic at all. It was sky high, and everywhere. It looked like somebody just burnt down a building
Old 03-06-2005, 02:30 AM
Zero10
Zero10's Avatar
Hows the smoke smell? What does it smell like?
I'm getting 0.6k/sec on the video....
Old 03-06-2005, 02:59 AM
StupEd05
StupEd05's Avatar
Smoke in the cabin is no good bro. Smoke out the tailpipe we can deal with, smoke in the cabin is not so good. Not so sure it is mechanical, as I wouldnt think a mechanical failure would be less likely to give warning, i.e. the limited RPMS. Check for a blown oil gasket of some sort, the bouncy oil pressure wouldnt necessarily be a headgasket. Sounds like an oil gasket blew, engine lagged because of extra oil pressure (not sure why???), causing the burst of an oil gasket which then sprayed oil all over hot engine and thus LOTS AND LOTS OF SMOKE! Best I can come up....
Quick Reply: The end of the blacky- COMPRESSION TEST RESULTS :(
