Wheel Lug Tourqe Question?
Old 10-30-2004, 09:23 PM
Turtle256
Turtle256's Avatar
Default Wheel Lug Tourqe Question?
Hello Again Everyone,
Okay, probably a stupid question, but I am putting my wheels back on and I looked up the tourqe spec in my Haynes manual and it say 98 ftlbs?! Does this seem like an awful lot for aluminum lug nuts ..... anyone have the correct tourqe spec? Thanks in advance.
Turtle
Old 10-30-2004, 09:24 PM
joseph mitro
joseph mitro's Avatar
95-98 is what i've always used
Old 10-30-2004, 09:27 PM
GlenL
GlenL's Avatar
Yes it seems like a lot. Yes it is correct for the aluminum lug nuts.
Old 10-30-2004, 09:41 PM
Matt H
Matt H's Avatar
96 is what I usually use but 95-98 is the range you want to be in. Further, if you think that is high you should check out some of the older Chevy pickup specs!
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 10-30-2004, 11:30 PM
gtroth
gtroth's Avatar
FSM calls for 130Nm (96 ftlb). They are also pretty draconian about using only the special tool P300 and no other sockets wrenches, and lubing with Optimoly TA. Personally, I don't obey the last two points.
Old 10-31-2004, 12:11 AM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
Mine set at 120Nm, even my 'tire guy' new this before i found out might add another 10Nm to be on the safe side
Old 10-31-2004, 12:17 AM
dualblade
dualblade's Avatar
is it a bad idea to use anti-seize on the lugs? will that cause the nuts to back off?
Old 10-31-2004, 12:20 AM
Chris_924s
Nerd Herder
Chris_924s's Avatar
NO anti sieze- keep the threads clean. 93lbs. thats what we use at the track.
Old 10-31-2004, 12:40 AM
IceShark
IceShark's Avatar
I use anti-seize on the lugs to prevent galling for years and no problems. And I'm not sure exactly what the lug nuts are made out of but it isn't just plain old aluminum so don't worry about 96 ft lbs of torque. Though when you track a car they want steel nuts used so there must be something less than great about lightweight nuts.
The controversy over anti-seize has to do with torque specs rather than having the nuts back off, well at least I think. Some of the old cars used to have opposite threads on the lugs on right and left sides to consider wheel rotation.
The anti-anti-seize theory goes if you don't get the crud off when you remove there is more resistance socking the nut down so you are actually under torque. If it is clean with anti-seize there isn't as much thread resistance so you over torque.
Old 10-31-2004, 01:05 PM
Dave951M
Dave951M's Avatar
95ft/lbs with anti seize compound. Aluminum is like steel, there are different alloys with different properties. Not all steel is hard, change the makeup or manufacture methods, and you can go from dead soft pot metal to stuff in the 90Rockwell range. Same thing with aluminum. I'd be it's in the 5051 series.
Old 10-31-2004, 03:26 PM
Turtle256
Turtle256's Avatar
Thumbs up
Wow, just wante to say that this board is the best. I posted a simple question and within a few hours so many responses. You guys are great! Good to be a member here.
Turtle
Old 11-01-2004, 04:02 PM
Jakerx
Hitsquad Ninja
Jakerx's Avatar
welcome to rennlist Turtle...yep it is a great place.
Old 11-01-2004, 04:08 PM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
I use 93 foot pounds... I didn't know it's sposed to be 98! damn
Old 11-01-2004, 04:45 PM
Rock
Lazer Beam Shooter
Rock's Avatar
how does one do this without a torque wrench
Old 11-01-2004, 04:50 PM
Mighty Shilling
Wax On, Wax Off
One without a torque wrench must first go to a tool shop and buy one.
Rock, if there is a Harbor Freight by you, go there. their torque wrench was proven to be one of the most accurate and it's pretty inexpensive...
Quick Reply: Wheel Lug Tourqe Question?
