new member! Carbon Fiber One (CF1)
#47
Originally posted by DanG
My bad streckfu. Well then either this GT or the AIR, but more aggressive than the B&W one originally posted.
The GT has more surface area and will generate more downforce than the AIR, however I feel the AIR is a much better looking piece (more OEM in appearance).
From what I've heard the AIR works better on the street as it allows a little more clearance. I have the GT and have to be pretty careful with driveways and dips.
#48
Well thank your for your inquiry, the products I am interested in include:
1. The 968 Turbo RS rear spoiler for a 944 Turbo.
2. A hood with:
A. Nacta duct to feed cold air to the intake (eg: behind left headlight)
B. A vent and duct work to extra hot inter cooler and possibly radiator air.
3. A carbon fiber intake with individual throttle bodies (944 Turbo)
4. A vented nose panel and headlight enclosure as a single piece. (This combines two well loved modifications)
A. Venting the Nose panel and adding duct work allows more air to be routed through the intercooler.
B. Many people would like to eliminate the pop-up headlights. (This reduces weight and improves aerodynamics. The 924 GTR, factory LeMans entry, has flat headlights that many people like. You might convince Ice Shark to advise on quality lighting options. )
Thanks,
Matt
2. A hood with:
Thanks,
Matt
#49
#50
I've scraped my AIR several times now. The bottom edge along the front doesn't look so pretty now, but it hasn't cracked from hitting anything yet.
If you mount it secure enough, you will find it hard to break. I hit a fox at 60 mph and all it did was break the speed nuts on the bumper cover causing the splitter to droop in the middle.
Functionality on the other hand...anybody have a wind tunnel? Or good at CFD analysis?
#51
I'd like to see an affordable carbon fiber hood thats under 400 bucks. Everywhere I look they cost an arm, a leg, and your left ball... My car needs a hood due to old bondo showing and I'd like to upgrade to carbonfiber, but paint the top of the hood because I refuse to have carbon fiber showing on the exterior of my car.
Andy
Andy
#52
I'll throw another vote on the turbo RS wing.
Also the notes about fixed headlight buckets. I think guys like myself and Matt H would be more concerned with a quality job here vs low cost. We both realize to be done properly it isn't going to be a simple thing.
ELLSSUU mentioned a foglight replacement brake duct for the turbo front fascia. That's a good idea. I've seen pictures of cars with those, but I've no idea where they're sold. I'd think the track guys would be all over those.
Lastly, there was a thread in the turbo/turbo S forum that had a pic of a CF intake that was intriguing:
https://rennlist.com/forums/showthre...ghlight=intake
#53
This is great and I dont know if you are still reading the board but can you may a complete tailight assembly that updates the look of hte car...i.e. gets rid of the borders and the orange color. You can work with the Rennlister for the lens specifics. This should have a broad based appeal for the complete 944 line....
#55
THis is the most excited I have seen you guys in awhile. CF1, it would be great if you came through. Even if only for a few of the items listed you'd make a lot of days for a lot of 994 owners!
Melissa
Melissa
#56
Originally posted by MelissaInNJ
THis is the most excited I have seen you guys in awhile. CF1, it would be great if you came through. Even if only for a few of the items listed you'd make a lot of days for a lot of 944 owners!
Melissa
Melissa
Melissa *expert typist!!!*
#58
could you make a duct that wouldnt be as small as a NACA but more of a scoop right behind driver headlight for us that want to keep our headlights...(me) and you cauld even have like a little bend of metal inside the hood that the air would hit and be forced down instead of traveling straight to the brakebooster?
#59
Real splitters are largely horizontal as these are. Much that the aftermarket for road cars call all sorts of junk "splitters" that really aren't. In fact, many of the same aftermarket companies talk about "ground effects" but really just mean silly body panels. True ground effects are managed underbody airflow that creates downforce such as the tunnels in Champ Cars or the diffusers in F1 cars.
Anyway, back to functionality....
While they are functional, the question remains regarding the effect on aero balance.
#60
I'd be really interested in parts that significantly reduce the weight of the car. As Colin Chapman said - to go faster - add lightness.
Anyone geeky enough to craft a spreadsheet detailing major components and their weight? Graphing that would show you where the "real" wins would be. (Might not all be parts that can be done in CF though.)
Maybe Magnesium trannys are the best bet - but $$$$! Oh, a CF torque tube might be a big win.
RK
RK
