The Baton is Passed...
#46
Was that a PBBlaster wipe down? That stuff is magic!
#48
Wait... What? PB blaster as a cleaner? How do I not know about this? What do you use it on? I would have thought it would be a bit corrosive. Smells corrosive.
When I first got into 944's, I spent most of the first year over on the 944Online forums. Ian and Steve are the GOATS. They just do all the work on kits and knowing the RIGHT parts for you. And are just great guys.
I find I make up excuses to support the shops like theirs. In a way, it's like voting on who gets to stay on the island... With money. I have a F9T prime fuel pump relay just because I want to support what Joe is doing. I've ordered stuff I didn't exactly NEED from Kyle, just because I appreciate the niche he fills. I just ordered new under hood insulation from Classic9 for the same reason, even though there were cheaper options out there. Rod didn't have the decals I wanted in stock, but we've been working together to get it done. I ordered the improved (and much more expensive) A/C tensioner bar from Jason at Paragon just because I love when someone innovates a new and better solution, just for our cars.
And every one of these people, and many I didn't mention, will bend over backwards to help you out with their knowledge.
Sorry... I kinda went off. I've been into Mustangs (my first car 34 years ago was a 68). I've been into F-bodies, love me a Firebird. Even founded a club. I've been into Corvettes, C3's forever! I've done the BMW thing, got a 740IL. But there is nothing like this community out there. And I just like to take every chance I get to recognize that.
mazdaverx7 (06-18-2023)
#50
I actually learned about PB Blaster from the antique motorcycle community as those guys would use the stuff as wax on turn of the century bikes (1900's). I was heavily involved with Indian Motorcycles back in the 90's, having owned pieces ranging back from a 1906 Camelback to the late 1920's Chiefs and Scouts. Here's an old pic of a couple that I was fortunate to own: The Black/Red Scout was an early 1928, 45" that was my daily driver for a couple of years.
Tiger03447 (01-18-2023)
#51
2) What parts were coated with it? Painted surfaces? Tires? Metal engine parts?
We want to know more!
Nice bikes!
#52
Are you asking about the bikes or our cars?
Motorcycles: Tin panels, frame and any other metal surfaces.
Our cars: Engine bay, undercarriage, suspension, shields, wheel wells, etc.
#53
Today's update:
New bushings were installed on the front sway bar as the old ones were shot. I also brought the exhaust to my buddy's shop for some R&R, should have it back sometime next week. In the meantime, I inspected the rear brakes for any excessive wear and they seemed to be in good shape (one less thing I have to take apart).
Before:
After:
Before:
After:
#54
Patrick you are a fanatic! But a good one keep at it. On a quick side note I have been involved in some serious family ordeals not health wise but money wise and just frustrating. Im hoping to have a lot of that behind me by late spring early summer. Ill post in the general forum Im sure some will chime in. Hopefully I can get in my car and stretch its legs and come see you and catch who ever is willing to hang out with a redneck from Texas on the way. Keep up the good work and not only do I need motivation but Im sure others feed off your devotion to getting it done.
#55
Hi Brad,
Sorry to hear about that; I think its happened to most of us - certainly to me several times over the course of my existence on this blue marble. I wish you only the best and please know that you are always welcome up here in Yankee Country; our guest room is open to all my fellow 944 friends.
BTW: Did you receive the decals I sent a few weeks ago?
#56
Another update I wanted to share with the group:
I really enjoy addressing small issues, especially when the snows are flying around outside (nothing beats a climate-controlled garage). Anyway, I discovered that the engine bay light circuit had an open, which caused a non-operational lamp. It required total disassembly of the light switch housing which contains a mercury switch:
Upon disassembly, I found the recessed cup of the socket cap had corroded, which prevented continuity. A little work with my Dremel cleaned that up.
A Safety Warning to all: Mercury is nasty stuff so be VERY careful while reassembling the switch so as not to break the glass and splatter mercury everywhere. I used an angled pick and small flat screwdriver to gently pull the plastic tabs while pressing in the cap.
And Voila!, it works (and turns off when lowering the hood, just as designed!
Another project checked off...
#58
Great work on that switch and thanks for sharing that. I doubt many people know how that works! I had assumed there was a little plunger switch where the hood hinge retracts; never considered a mercury switch behind the light socket! Doesn't the operation of the light require the hood to be raised and also the blinker to be activated, or something weird like that?
#59
I can't remember the exact combo to get the turn signal thing to work. I did test it however when I got the hood light working, and it does work.
#60
Some Googling says the underhood light is powered by and linked to the left turn signal lights. AKA, if the left turn signal/running light is on (has power), the hood light will also come on. It can be on because the lights are on, the running lights are on, OR if you have the ignition off, the left marker lights are on. The only criteria for the hood light to come on is the left lights have power, and the hood is open, making a contact through the mercury switch. My 86 ALSO has a hood switch, right up by the brake master cylinder. But I think what was only used by the alarm. (That's what I use if for now)
The 1987 manual I have (I've never been able to find a PDF of an 86) does not mention this. And I saw some discussion that the "turn signal marker lights with the ignition off" thing may only but up to 1986. Either way, the idea was when parked, you could lock up the car, but have your street side marker lights on at night so people could see you. I have always thought it was the right-maker light (for left-hand side countries) but the discussion I saw said it was the left. To me, that would be US or right-hand side drive cars.
Either way, I do remember I did test it when I replaced my hood light 3-4 years ago, and it did work with the ignition off and one or the other of the blinkers on. (Of course, it doesn't blink with the ignition off. Just comes on solid. All markers on that side.) I'm in St Louis and about 300 miles from the car, or I would re-verify to have the info out there.
