1984 944 Zobelbraun metallic Project
#31
Oh man! I'm excited for you yet simultaneously sympathetic. That is a whole lot of assembly and while none of it is really difficult... not having removed it, at least once, makes it a great deal more challenging. I really hope the paint can be saved so you won't have to go too far backward. It may be beneficial to find another early 944 local to you to be used as a model for reassembly.
https://fuelsafe.com/sending-unit-fuel-sender/
#32
Gasngo, Thx for the comments. Sounds like you're having the same fun as me. I did get the transaxle out last night. Really not that hard at all. 4 bolts on the bellhousing and 2 holding the mounts. I had to be careful of the plastic shift rod tube but it didn't get damaged. Thx for the link for the sender. I does say SAE 5 hole mounting pattern,I wonder if that would line up with the 944s 5 bolts? I was planning to try to save my original, or probably buy a used one. This is a good option though
As for the 530i, its a great car. I got lucky with this one. It sat in an underground for 28 years. so its almost rust free which is rare for these rustbuckets. It was complete, unmolested, the interior is pretty mint. It had a lot of problems similar to this car from sitting . The fuel tank was rusted right through. And yeah the dash is beautiful in these old e12s VS the newer e28. I equate the e12 to the e28 in a similar way as the early 944 to the late 944. Both early versions are more old fashioned, more Euroish looking IMHO. Weirder and quirky. Unlike the 944 the BMW e12 was an ungalvanized rusting nightmare. For those of you not interested in BMWs, my apologies for mentioning them here. I know its probably Verboten!
Both the 530 and 944 were cars I drooled over when I was younger so its great own another dream car of mine. Only a hundred more to go. LOL
Also thx for the offer of help. I appreciate it. I may PM you if I do run into a problem. Keep watching here, I'm sure you'll see me get into all kinds of trouble. I'm pretty good with the BMWs but this is the first Pcar I've had and I'm out of my league right now, although so its been great , I definitely think these cars are easier to work on in many ways compared to some others. Although burying the tank in the middle of the car isn't so convenient Haha. I would be pulling the tranaxle anyways to reseal etc anyways . Next for me will be getting that tank out. Not sure when I'll be able to tackle that with Christmas etc. Cheers Dave
joseph mitro (01-04-2022)
#34
I believe the OE sender is SAE now that being I have not actually got a caliper and put the exacts to it but Im pretty sure. Clarks Garage Web site has the specs on ohms and that unit fits as good as its going to get. If you find a good used one run with it but my money will go new most likely. There a was post on that sender somewhere in the forum Ill find it eventually.
#35
I believe the OE sender is SAE now that being I have not actually got a caliper and put the exacts to it but Im pretty sure. Clarks Garage Web site has the specs on ohms and that unit fits as good as its going to get. If you find a good used one ruin with it but my money will go new most likely. There a was post on that sender somewhere in the forum Ill find it eventually.
#36
Few pics of the greasy dirt caked lump of transaxle . Amazing how much dirt was caked on it. This car must have been driven down a lot of dirt roads. The oil that came out of it didn't look bad at all.
Both mounts looked good when still in the car but have separated
#37
The Ole puddy knife! I yet have had a chance to get me car to the lift but from what I saw Ill experience the same thing. Are you thinking short shifter. I know mine is loose and its one of the things I thought I would do while its apart. I have done done tid bits of reading but not enough to narrow down what would be best. Stay at it. Got tot run here.
#38
#39
Nice progress! As a side note: please be sure that the two small spacers (dowel sleeves) present on the bellhousing (or transaxle) to properly align the transaxle during reassembly. Sometimes they go missing which results in a slightly askewed alignment (part no. 46 : 019-301-153).
#40
pfarah7, Thx for the heads up. I'm aware or the alignment dowels, and they are both present in the transaxle bellhousing. I made sure I cleaned ,polished and lubed the ones in my BMW bellhousing when doing the manual swap. I've read stories of guys having all kinds of problems getting the dowels to slide nicely into their holes and cause grief during installation. with all the dirt and crap on this one its a full on cleaning project. I appreciate the advise
#41
Not wanting to purchase the new transmission mounts for my car, they were starting to de-laminate, but not as bad as yours, I filled them with 3m window sealant/urethane compound. Hope that they hold up.Mine sat in a field for about 10 years..let me know if you need help..glad to assist. See if you can contact VDO America direct..about the sender..they won't sell to you unless you're an authorized vendor...but you can find one that will help you beat the high cost of Porsche..I did this when I used a VDO sender for another car project...required a custom built fuel gauge, and the builder wanted the sender prior to starting the project for calibration. I used the VDO unit because it was easier to put into the fuel cell...BTW..don't take it apart there are very fine guide wires inside that will break by looking at them. just sayin..
#42
I took apart a sender for my BMW and I'd say they are the exact same construction. I managed to clean it all without damaging the wires. I've also seen a tutorial on the e9 coupe forum I believe of a guy resoldering new wire into a sender to repair it.
Thx for the tips, I appreciate it.
Dave
#43
OK so a few more little updates. I haven't done much over Christmas. I did manage to to clean up the transaxle a bit more. I also pulled off the balance shaft pulleys and the rear timing cover to so I could have a look at the water pump. The PO put a new one in years ago just before his resto stalled, I was hoping it would be OK even after sitting for so long but no luck there. There as a bit of a mess in there and the pump looks nasty. I guess there was a little coolant left inside .
Looks like a Genuine Porsche pump? Too bad it never even got to go into service
The pump area of the block cleaned up ok though. I also remove the front spark plug to put my borescope down but being at TDC the piston is right there stopping the camera.
#45
