I Want To Order These Headers But...
The company said the oil line doesn't come with it. Where can I find one already made that will work with them? I know their not the best headers out there but I only put very few miles on my car and I think the will be fine for me.
http://cgi.ebay.com/ebaymotors/OBX-T...30460016QQrdZ1
Another problem with those headers is that they have drilled the wrong OD for all the mounting holes.
To be more specific, the turbine side holes are to small and the header to cylinder heads are way to large.. You get a constant exhaust leak, from the movement of the header..
See my thread here (pictures are on page 3):
http://forums.pelicanparts.com/showt...hreadid=345731
Originally Posted by Bernard
Thanks for that info... Where did you get that oil line to hook to the small tank?
I had a early set in my own hands. If they corrected the hole sizing, they should be "great" for the money..
Basically what they did is flip the hole sizes.. The turbine inlet flange was drilled to fit a 8 x 1.25 and the header flanges were 10 x 1.5 studs.
Benard,
Just call Stephen at IA and he will fix you up. You will also need the little tank that collects oil from the turbo bearing. Most header companies include the tank. You will need a hose from the tank back to the sump and from there to the thermostat in the right wheel well. I got mine from Vertex and it is a hard line and a OEM type hose from the hard line to the thermostat. You will be replacing the line that currently runs from the thermostat behind the rear of the engine to the pump on the forward left side of the engine. Some people use a SS braided hose for both. Good luck.
Originally Posted by 911rudy
Benard,
PS: The good luck part scares me
Originally Posted by DDD
Sandman,
Can up feel any difference between OBX and the B+Bs in performance and turbo spooling times?
Do the OBX lead to boost creep?
Sandman,
Did it come with the various gaskets, oil line, drip tank? Or was there any stuff you needed to get seperately?
I assume the flange holes where all drilled to the correct size?
Thanks!
Thanks!
And yes, the flange holes on mine were fine...
