9m 1972 911S repair & restoration - back to original or not?
#332
Many owners have no emotional attachment to the car. It was a prop in their quest to get laid, and nothing more.
#333
At last we have straightened and reinforced rear trailing arms; now we just need to fit a pair of new wheel bearings, mask, primer, paint and fit.
#335
Grey plastic duct freshly painted, riveted back onto fan shroud and the shroud in place on the engine with the rebuilt engine harness.
#337
Yup, that's me alright, piloting my 993RSCS up Longleat Speed Hillclimb and setting a new Porsche record for the hill. Powered by the 460hp prototype 9m 4.0 litre race engine, stock RS gearbox, stock RS suspension (!), 9m AP 6 pot 343mm front brake upgrade. The chatter noise over the top of the hill is the LSD working the inside wheel on lift-off turn-in and definitely not a wastegate!
#341
Thanks for finding that for me Amber ! The number is the one that was given to the car when it was imported to Ireland circa 1983 or 1985. ZT is the letters for County Cork in 1935 and it got 911 as there would not have been 911 new cars registered that year.
#345
Engine time again.
The white residue encrusted onto the plastic throttle stacks was removed by gently scraping it with the blade of a small blunt screwdriver; a polish with WD40 and we were good to go. Mark fitted the clean intakes, the MFI pump and fuel lines, so now we are only waiting on the drive pulleys and belt for the MFI pump and a set of cleaned injectors. More on the injectors later.
