Finally Starting my 3.2 to 3.4 Conversion
If you look at my case, at the top, there is a ring or line where the seal is. That's where it leaks. Let me try to re-post with an arrow. I may have to point at it unless someone else knows how to put the arrow on it at the top where the seal is.
Team Owner
oh i see now .. so it just leaks past the end bearing ? okay now i need to ask a REALLY dumb question . As i have neveer had my engine that far apart .. what end is that ? they flywheel end or the crank pulley end ? and how would I know if it were leaking ?
Actually I was getting far too much smoke coming out of the exhaust at intersections. I have less than 100k so I'm not sure why this was happening. So, I just decided to start all over again with the motor both top and bottom.
Team Owner
so that can not be replaced with the engine in the car .. it has to be torn down ? wow . i guess I iwll kep an eye on that part of the car .. see if it starts to leak any more than all the others ..
Ice... don't feel bad. I ask dumb questions all the time. I just have a good team around me. That's how you learn...
I always believe in: Learn as though your going to live forever. Live each day as though it's your last.
