718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
OEM Navigation Retrofit DIY
Old 12-18-2022, 08:34 PM
  #316
Z06jerry
Z06jerry's Avatar
Originally Posted by Westcoast
Interesting, so you are saying that the time when set by GPS is not correct? Here in BC, we observe the spring/fall time changes and when I have the car as is shown in the picture above it always has the correct time.
yes that is what I'm saying, it's +1hr as if it's displaying DST when we are now on standard time. My temporary workaround is to change my time zone to Central GMT +6 instead of my actual zone which is Eastern GMT +5
Originally Posted by 718socal
@Z06jerry @West Coast there is a DST option in the cluster but it is not enabled by default. If I check it in the cluster, my time is off by an hour (+1) with Automatic Time Synch. We never enabled this on your car so I don't know why your time is off.
@718socal Sounds like my cluster may be defaulted to DST without the ability to de-select it. I'll have to put that on my wish list for future coding!
Old 12-19-2022, 09:01 PM
  #317
nobbyv
nobbyv's Avatar
Has anyone been able to code the cluster to show the nav using Launch431? I've been back and forth through it and can't find anything that looks like the PIWIS screenshots.
cbracerx (12-20-2022)
Old 01-02-2023, 05:00 PM
  #318
718socal
718socal's Avatar
New 2022-2023 map P87 here
https://mibsolution.one/#/1/15/MHI2(Q)
(Username and password guest)
The following 2 users liked this post by 718socal:
cbracerx (01-02-2023), Z06jerry (01-03-2023)
Old 01-02-2023, 05:27 PM
  #319
Westcoast
Westcoast's Avatar
Received 4,696 Likes on 2,733 Posts
Thanks for the heads up, it is on its way down!
718socal (01-02-2023)
Old 01-02-2023, 06:44 PM
  #320
sgreer78
sgreer78's Avatar
I guess I deleted it, what's the preferred download manager to use for maps?
Old 01-02-2023, 07:16 PM
  #321
718socal
718socal's Avatar
I used the one above for Windows. Did you use your VM to download or straight to your Mac?
Old 01-02-2023, 07:35 PM
  #322
nitesho
nitesho's Avatar
Hats off to everyone that figured this out and to the brave souls that tackled it.
I'd pay someone to do this for me if you're in Los Angeles.
I considered getting the system from suncoast but it's $1800 or so.
I have apple car play but hate that interface.
Old 01-02-2023, 08:17 PM
  #323
NukeThemTillThey
NukeThemTillThey's Avatar
Thanks for rhe heads up on the update. Couple of questions.
  1. is there a notification option for new updates on the MIB site?
  2. Is there an OTA option? Just curious, I do have factory Nav and Connect.
Old 01-02-2023, 09:38 PM
  #324
Westcoast
Westcoast's Avatar
No notifications of updates from the MIB site that I know of.
Yes, there is an OTA option for NAV updates, I tried it a number of times, never got it to work for anything other than a small subsection of the map and that still took forever. The entire update as one file makes a whole lot more sense.
Old 01-02-2023, 11:12 PM
  #325
718socal
718socal's Avatar
Update
Please use the AIO method to enable NAV, Carplay and Android Auto.
I cannot edit the original posts. Here are the latest links for the AIO method.
Follow post 56 here.
Instructions from MIB Wiki
https://mibwiki.one/share/30b7c0f9-a...1-20f4309ef4bb
sictiru (03-07-2023)
Old 01-03-2023, 12:22 AM
  #326
sgreer78
sgreer78's Avatar
I'm pretty sure I did the maps straight to my Mac, but maybe I did it to the windows laptop. I'll fire it up tomorrow and see. Thanks
Old 01-03-2023, 12:51 AM
  #327
718socal
718socal's Avatar
Free Download Manager
https://www.freedownloadmanager.org/
Old 01-03-2023, 01:09 AM
  #328
NukeThemTillThey
Thanks, you just confirmed what I thought was the case. I will grab the new map files in the am and update later.
Old 01-03-2023, 01:03 PM
  #329
vtplm
vtplm's Avatar
I did this a few days ago and everything seemed to go smoothly. Nav works as intended. My AA is confirmed in GEM but doesn't seem to recognize my phone though (no icon changes) on the main pcm menu. My phone charges appropriately via USB in the arm rest. Anyone have any clues for troubleshooting? I'm going to swap out my cable once I can find another.
Old 01-03-2023, 01:12 PM
  #330
Westcoast
Westcoast's Avatar
What 'exactly' did you do, take apart the dash and install cables or... ? Did you use AIO? What do you mean no icon changes, do you see the Android Auto icon?
You also say "seemed to go smoothly " but did it complete as per the video tutorial?
Quick Reply: OEM Navigation Retrofit DIY
