Brake Dust
Not sure about this but I've read that one downside to the (larger) pccb is that they won't fit 19" wheels whereas the iron brakes would -- in case you want to change to less wheel, more rubber setup for back-roads or for more (and cheaper) tire choices for the track.
When I was looking at tire prices, it wasn't a huge difference between 19s and 20s. maybe $100-150 a set. Depends heavily on the tire of course. I was looking at the RE71R but it's been a couple months.
That having been said, most reviewers have said the car doesn't seem to understeer like the 981, which was primarily the reason for larger rubber/smaller wheels.
And in my experience, Outlast does a waaaayyyy better job than any of the coatings or waxes at keeping brake dust off the wheels. If Outlast doesn't get the job done, nothing will. And I heard from a number of 981 GT4 owners that nothing, including Outlast, could manage the dust from their brakes. And I saw a GT4 come in for service once while I was at the dealer, with more dust caked on the wheels than I thought would be physically possible.
Is this referring to iron or pccb and which P models?
More rubber sometimes helps the stiffest sport setting on imperfect backroads.
There used to be much more tire choices in 18 and 19” vs 20” at various price ranges. The $ diff between 19 and 20 on the same tire model should not be too big.
https://rennlist.com/forums/991-gt3-...cb-brakes.html
https://rennlist.com/forums/991-gt3-...-question.html
https://rennlist.com/forums/991/1062...e-problem.html
There are certainly wheels that fit. Some better than others.
When tire choices were few, then manufacturers could charge whatever they wanted for the difference between 19 and 20. more cars have 20s which means more supply.
I did CQuartz on my Golf R and I'd never do it again. It was nowhere near as good as the OptiCoat Pro Plus on my other cars.
Thanks for the CQuartz feedback it helps, got a '19 Golf R with the same issue was thinking it would help and maybe be a solution for the new GT4. Golf R is wrapped in Xpel no complaints but have no experience with their new fusion ceramic coating but was thinking of trying it as an alternative. Anyone with Xpel Fusion experience its greatly appreciated if you could share.
I was really disappointed in how poorly CQuartz shed water on the car. My OptiCoated cars just shed water right off when I blow dry them. The water droplets gripped the CQuartz car and I wound up having to towel dry the car more than I'd want to. And that car showed water spots worse than any of my Opti cars.
Targeted at the serious performance-minded owner, 18” SM-10 wheels clear up to 380mm rotor, 6-piston brake kits including the factory PCCB’s.
I’m picking up my Spyder with irons (and silver wheels) in two weeks, here in Germany. I had PCCBs on my previous two Porsches so I’m also curious how much dust the Spyder will have. I’ll keep an eye on this and report back.
Ahhh yes, they have been out in the wild for months everywhere else but in North America!
I had cast iron on all of my previous Boxsters, not only did I find the brake dust bad but the rusty water on the barrels was a real pain! Interestingly GM developed a treatment for the rotors that virtually eliminates the dust and rust and extends the life of the rotors, developed here in Canada, on my GMC truck the wheels and rotors are always free from pad dust or rust.
If you find the idea interesting here is a brief snip on the process: https://www.theglobeandmail.com/glob...ticle11408699/
https://www.motortrend.com/news/gm-p...models-140867/
Interesting. Motorcycles use stainless steel rotors and have for many years. I don’t understand why no car manufacturers (to my knowledge) use them. I’ve read that iron dissipates heat better, but if high performance bikes use them, I don’t see why they can’t be used for cars. Perhaps the reason is that they would wear out too fast. Since bikes typically don’t accumulate mileage like cars, I guess that wearing them out early wouldn’t be an issue. I don’t know...but it’s annoying that the disks on my dirt bike are always shinny when those on my cars get rusty.
