Cayenne Engine Replacement
#211
Former Vendor
I've had so much Cayenne engine interest that I added a Cayenne engine rebuild class to my 2015 hands on schedule..
That said setting cam timing is easy. You will need the Porsche special tools, which are both fitted simultaneously with the engine at TDC and the chain tensioner installed. The long timing chain makes things difficult and you may have to try the settings 10+ times to correctly allocate the cams so valve timing deviations don't occur.
#214
But you can borrow my Piwis 2 if needed and I have oem tool to fill transmission as well as the tool to fill coolant and remove air from system.
I'm in Hamilton
#219
No Worries, I bought them from Porsche, 182$
The Crank Pulley seal with installation sleeve was $300...
Here is an updated pic.
Need to install the tensioner and time the cams and I'll be on my way I suppose...
Looking for recommendations for Break-in oil for this thing... Jake?
Thanks again for the help along the way. I can see the light at the end of the tunnel now, I think...
Regards,
Jonathon
Regards,
Jonathon
#221
Former Vendor
Regards,
Jonathon
Regards,
Jonathon
I usually have to correct timing 5-6 times before I am happy with it.
As for break in oil, use Joe Gibbs BR30 and run it 300 miles.
#223
Former Vendor
Happy to help... Also, pump the tensioner up in warm thin oil as tight as you can get it. This is a secret that takes a while to learn.
Glad to see you tackle this.
#224
Well, without too much stress and difficulty, I was able to successfully install the tensioner and time the cams!
Many thanks to this forum and Jake for help along the way. This is a big milestone for me so I am very happy right now.
I have to order some more o-rings again, so that I can re-install the oil-water heat exchanger with oil filter. Then I can install idler, water pump, alternator, a/c compressor, p/s pump, headers, coolant pipes, RMS, little cover plate, fly wheel, etc etc etc!
The light is getting brighter at the end of the tunnel...
Cheers
Cheers
