Catastrophic Coolant Hose Coupling Failure Registry
#512
One of the shops that does tech inspections for the cars that run in my region changes out the 2 main coolant hoses every 2 years since they take such a beating due to heat when the car is used on the track.
#514
How is the condition of the rest of the hoses?
When i had my engine out I was interested in changing hoses and the dealer said they were fine and its not a issue they see with any of the cars...
#515
The other hoses were inspected and appear to be fine. The Porsche shop I do business with recommends wiring the hoses and clamps, to prevent the clamps from coming apart. He does it on all of the Cup Cars because it appears to be a bigger problem with them.
#516
Hmmm...anyone pissed that you are so much faster than they are? ;-)
Not a bad idea. My shop also replaced most of the spring clips with high quality hose clamps with flared edges that prevent them from cutting into the hoses.
#518
The hose clamps that my builder uses on all Cup/GT3 engines are made by ABA Sweden, also very high quality. I looked the ABA clamps closely (rolled edges, no slots cut through the band, designed to apply even pressure and one-piece clamp housing) but I did not have the opportunity to compare side by side with what came off.
#519
GT3 player par excellence
i saw fitting, clamps in person.
no matter you track or not
no matter what mileage your car is
it's death, it's certain.
u roll your OWN dice.
pin or weld it.
no need to debate about cup car this or that.
just do it. and you will be happy.
u can blame porsche from your grave when you spin out and hit something..... its 4-5000, you drive a 100k car.. think about it.
pin or weld it.
#521
pin or weld it.
pin or weld it.
#522
For most of the country it is the off-season anyway. Give a universal gift and gain peace of mind - just get it done!
#523
+GT3
+Turbo
Please and thank you!
#524
I’m probably not going to win any friends with this post.
Let me first say the time has come for me to get my coolant fittings welded / pinned (2011 997.2 RS, 20k miles). I think it’s completely unreasonable for anybody to expect I would have done this when the car was new, even knowing earlier models are prone to coolant fitting problems and the consequences. Porsche has refused to publicly acknowledge the issue but they’re certainly aware of it and -- for what little we know -- they could have quietly addressed the problem on later models.
As a precaution, I’ve been running water wetter and I have my car inspected regularly. I made the heartbreaking decision not to fly down to Sonoma from Seattle earlier this year while my car sat trackside on the transporter because the car was losing a small amount of water the weekend prior at Laguna. I didn’t want to risk my safety or put others at risk. It turned out to to be the right choice because one of the coolant fittings was starting to back-out.
IMO, I’ve taken reasonable precautions for the safety of myself and others when it comes to the coolant fitting issue. Knowing that my car is in-fact prone to the issue *and* is ready for the fix, it will not be going on track again until after having fittings welded / pinned (great job for Winter).
There seems to be a growing sentiment that if you don’t have your fittings welded / pinned then you’re to blame for anything that goes wrong, and I see rennlisters being angry with other rennlisters. Here’s my perspective FWIW:
Mooty, respectfully, the reason I didn’t indiscriminately drop a measly $4-5k on my $100k car is because I do think about it and I don’t have an unlimited budget to a priori eliminate all potential failure points. (Coolant fittings, CL hubs, cam sprocket bolt, etc.) Like everybody here -- whether they care to admit it or not -- I accept the engineering economics of $$$ vs safety.
Since we’re on the topic, I’ll take this opportunity to remind folks of Porsche recommended maintenance intervals for track use:
Every 4,200 miles - Replace CL nuts, rear wheel hubs, and rear wheel bearings.
Every 8,400 miles - Front wheel hubs, front wheel bearings, and rear wheel carrier set.
Every 16,800 miles - Front wheel carrier set.
Coolant fittings are not the only thing that need attending to for the safety on the track.
If you’re angry because your car was compromised by someone else’s GT/Turbo motor dumping coolant on the track, then I suggest you direct your anger towards Porsche for not addressing this well known issue. The GT3/RS is a car built by Porsche for the track, and if blame is to be assigned if falls squarely on Porsche.
If you’re angry because your car was compromised by someone else’s GT/Turbo motor dumping coolant on the track, then I suggest you rethink going to the track. $hit happens on the track and drivers knowingly accept the risks and consequences of being on track before heading out. If it’s not a GT/Turbo car dumping coolant, then it’s a Ford dumping oil, some POS racecar spilling fuel, etc. Anybody who hasn't had to deal with this hasn't been driving for very long.
If you’re angry because your car was compromised by someone else’s GT/Turbo motor dumping coolant on the track, maybe you should ask yourself what you could have done to help avoid the situation. Were you bump drafting a car you know nothing about driven by somebody you don’t even know on a hot-lapping day? Why? Did your ego or peer pressure lead you to turn off your ‘nannies’? Then I invite you to look only in the mirror for person to blame if your car has such aides. Not suggesting all situation can be avoided -- refer to previous point.
#525
^ noted and u caught me with my pants down.
1. when these cars are new, i would not take the perfectly good motor out to weld or pin. that's not my point. but now, they are getting older. and it should be budgeted. 3 sets of hoosiers would do it.
2. water wetter is a good temp sol'n as many of us, myself inc, have used when car is fairly new.
3. i agree that trackers shouldn't be angry or blame others should their car be compromised due to others coolant or any other failure. like u said, sh*t happens on track. i have lost many cars on track... but personally i do not want to be the one who started a pile up. so i worry about my own car peeing.... should i run over other ppl's coolant, then it is a risk i take when i am on track.
4. yes, hubs and bearings are also failure points. i should know b/c other ppl's windshields, fender liners and yes tires with wheels and uprights attached have all flown toward, over, and under me....
5. indeed, if any anger should exist, it's toward porsche. i think most of us are in general worried about other's safety, like you not flying down to seattle. most of us are level headed, despite the occasional inappropriate lashing out ;-)
6. and your post will not lose you any friends. and if you do, then those are prolly friends not worth having anyways b/c when we drive on track long enough, we know... and i know that you know too.
