Looking for 964 Turbo
#91
Interesting that Hagerty has finally figured out that the true #1 MY 94 turbo can fetch up to $345k or more with the fair conditioned car worth only $129k. They had them clumped together for so long. Apparently they are learning it is all about condition and not model.
#94
Hey, question for you guys. The original window sticker for that car says "heated mirrors". Do we all have heated mirrors by default for our cars? I recall reading somewhere that Porsche directed some heat through tubing to heat the mirrors. Plus I also did not think it was a specific "Option".
#95
As I said, I had my mirrors off but didn't recall any power leads connecting to the mirror glass but I must have connected them per this wiring diagram:
#96
Wow,... put some Aerospace303 on that tail rubber!!
http://www.ebay.com/itm/1991-Porsche...m=222407912795
Currently found Qty 11 3.3 Turbo's (1991 & 1992) for sale here in the US. Did not scrutinize each.
#97
#98
No helping that. Needs to be replaced. I have a product that would make it look good for a month or two ( can't get it in CA) but eventually that will look as dried out as it is.
A lot of scary stuff on the market. It reminds me of when i was looking for homes back in 92. Everything was the left over crap that people overpaid for just a few years earlier and the good stuff people battled over.
#99
I wiped it down with lacquer thinner to removed the oxidized layer of rubber and have treated it with Aerospace 303 3-4 times a year for 10 years now. It doesn't look new but it doesn't look bad either.
#100
There are so many things going on with this car i wouldn't know where to begin. The A/C hoses might be a good place. I bet it blows cold air. LOL
#101
Here you go...
http://www.ebay.com/itm/1992-Porsche...m=311798419651
I don't know about this special ordered car. Weird build if this is true.
#102
Here you go...
Something is going on here. Is it me or are the calipers painted red over the black. It looks as though they taped over the lettering and painted the rest red. I have seen the turbo S flachbau in this color and it looked different to me. But who knows. I also wonder what is going on with the hood. WHy is it so poorly aligned if it only has 717 miles. Also someone cut the front carpeting to put the tech art camber bar in and I doubt the tech art lights are factory.
There is a plaque on the air bag passenger side. If it says anything why no picture? I guess if there is some truth it will find a buyer but I am not so sure.
Besides 308 would make it the second to last 3.3 imported not the last so deduct $100,000. LOL
#103
Also didn't know you could order Speediness from the factory in 1992?
#104
Mine does the same thing. I never noticed it when standing up close, and then a RL'er mentioned the same thing about a different car & I stepped back to look at mine.
It has the same illusion.
But you are right,.. the calipers are strange with that black behind the letters.
#105
I discounted thinking that if you had contacts you might have been able to order them since they were standard on the 92 ROW TurboS. Atlhough if they were period correct the valve stems should be at the spoke vs the later style that moved the valve stem between the spokes.
I don't think the hood is poorly aligned. I believe it is the long single piece rubber seal along the entire length that rises up & slightly over top of the front edge of each fender.
I also just noticed that it is a Tech Art front splitter and not a factory unit. No doubt this was done later.
It might be a nice car but for this money a lot of research needs to be done. Also if the owner does not have all records and the original window sticker I would have to question what this car is all about. You would think if it was show car that everything would have been saved and documented.
Is it me or does it look as though the license plate plugs have been painted over? Also the shell oil sticker is in the wrong place and appears to be the larger Car bone version.
