Heater bypass - definitive wiring solution
Hi all,
I was a little tired to see that single red cable hanging around my engine bay... Just didn't look right...!
So i spent some time looking for a better way of getting a switched lead...and i found it!
Remove the green relay; now remove the relay support (2 8mm bolts). Underneath the green relay there's a violet (maybe green/yellow on early cars) wire: that's it! With the help of a tap-in squeeze connector, connect a wire to that violet one (I chose yellow because it usually stands for "switched +").
Now terminate the new wire with an appropriate spade, put everything back togather and you're done! Simple, effective and clear.
Ciao
Ciao
Jaime_911 (08-08-2022)
I disn't, beause i'm pretty sure that violet line is already protected....but you can add a small fuse if you feel safer...
The violet wire is 0,5, so it's ment to carry a very little amount of current (means safe to me...)
Hey Anto, what gauge wire did you use?
I tried this earlier today but my fans shut down. I put my old set up back (cross connect + and ground) and then they worked again.
Possibly that the connector hasn't cut through the purple wire but I think so. My yellow wire looks like the same size as yours.
Good job. The violet wire is Terminal X, it's fused, and this modification will only introduce a very small current draw, if any. It connects to the Climate Control Unit rear fan feedback signal input.
Cheers,
Tore
Cheers,
Tore
So this is working for you guys?
I haven't done anything to mine yet after the RS bypass duct was added and my heater works fine. I feel like I should even mess.
I was gonna do the wire mod from the coil, until I saw this, but it seems like I don't even need to do either.
Now it works! The blade in the connector had pushed the wire outwards instead of through it. 12V it is!
Better than my old cross jumper fix? i don't know, but probably.
Thomas
Thomas
C2_trga (06-08-2021)
