Fuel Vapor Purge delete step by step?
Old 07-21-2010, 08:44 PM
jasonlp
jasonlp's Avatar
Default Fuel Vapor Purge delete step by step?
I can't seem to find a write up on how to delete the system. Is there one floating around?
Old 07-21-2010, 09:50 PM
reno808
reno808's Avatar
search
Old 07-21-2010, 09:55 PM
jasonlp
jasonlp's Avatar
Originally Posted by reno808
search
I only previously found these, of which neither has a dedicated step by step writeup
https://rennlist.com/forums/944-turb...em-delete.html
https://rennlist.com/forums/944-turb...ge-delete.html
Old 07-21-2010, 10:09 PM
Adonay
Adonay's Avatar
I would like this as well or maybe i should write one ...
Old 07-22-2010, 05:14 PM
reno808
reno808's Avatar
look for my screen name i posted some stuff. the first link pretty much says it all. you dont need at step by step
Old 07-23-2010, 12:33 AM
xsboost90
xsboost90's Avatar
alot of american cars vent at the tank with a small box that prob. has a carbon filter- im thinking of deleting mine and installing one of these small carbon filters.
Old 08-30-2011, 10:12 AM
zerMATT951
zerMATT951's Avatar
Reviving this old thread because I'm about to do this on my car. Found this fuel evaporation line diagram in another thread along with a little more instruction to help with the previously mentioned two links.
https://rennlist.com/forums/944-turb...vap-stuff.html
(ignore the comments in red... the questions are answered in the attached thread... this is just FYI for future searches)
Old 09-15-2011, 01:40 AM
beebone
beebone's Avatar
Yeah, that what my previously owner did. But I didn't find anything bad, no gas smell.
Take care of the hoses seal esp the J-boot, throttle body, sensor vacum.....
I delete the cyclinder valve and took the metal pipe out under the intake. Very clean now.
Old 01-29-2016, 01:05 AM
Doyle623
Doyle623's Avatar
I meant to post here but posted this on the water cooled forum by accident. Anyways, I've looked through all of the evap delete threads and have a question.. I looked at the lines coming from tank to the front of the car and it appears that there are 3. A braided-looking line, a rubber line going from the pump/filter and a 3rd rubber line (coming from the upper part of the tank). From everyone's accounts of putting a vent filter back there, it appears that the "other" black rubber hose would the be one the could fit the 1/2" filter I bought. Could someone please confirm?
Old 01-29-2016, 07:25 PM
mahoney944
mahoney944's Avatar
I did this mod along time ago. The line runs along with the fuel lines. Its easiest to start at the canister and follow it back to the tank, but its the line that has a short hose on it near the passenger floor pan. It runs back to the tank just cut it as far back as you can and install a filter to let it breathe
The filter I used looks like this, http://www.pinellaspowerproducts.com...FUELFILTER.jpg I cut the hose above the passenger CV axle, bought from advanced auto parts for like $10. Ive had no gas smells, or any tank pressure issues either.
Quick Reply: Fuel Vapor Purge delete step by step?
