Fuel Vapour Purge system Delete
Old 10-17-2009 | 01:35 AM
beebone's Avatar
beebone
Default Fuel Vapour Purge system Delete
Folks,
The prviously owner of my MY89 951 deleted the Fuel Vapour Purge system, the rest of vacum hosed were blocked. So any physical advantage / disadvantage for vapur purge delete?
Old 10-17-2009 | 01:59 AM
LFA951's Avatar
LFA951
Dont forget the big round cannister in front of the driver's side wheel well, under the side fender, behind the front tire, I did it years ago...advantages, one less vaccuum line and a little less weight...
Old 10-17-2009 | 02:23 AM
CarbonRevo's Avatar
CarbonRevo
Any side affects to doing this? Doesn't the fuel system need vented?
Old 10-17-2009 | 02:25 AM
beebone's Avatar
beebone
Yup, cannister also removed as well.
Old 10-17-2009 | 02:31 AM
951_RS's Avatar
951_RS
yeah what disadvantage here
Old 10-17-2009 | 03:16 AM
CarbonRevo's Avatar
CarbonRevo
It cleans the engine bay up sooo much. Already did it on the the turbo, just need the proper procedure to make sure it's done right.
Old 10-17-2009 | 03:26 AM
V2Rocket's Avatar
V2Rocket
Rainman
probably fail emissions test.
Old 10-17-2009 | 03:55 AM
beebone's Avatar
beebone
My side is ok for emission, I'm in HK. The old car before 1991 shd not meet the emssion test.
Old 10-17-2009 | 04:46 AM
CarbonRevo's Avatar
CarbonRevo
Emissions test? What's that?
Old 10-17-2009 | 05:37 AM
beebone's Avatar
beebone
yeah right. My car doesn;t need to equip with cat.
Old 10-18-2009 | 02:51 AM
eniac's Avatar
eniac
As long as it's vented to atmosphere back at the tank, it can all be removed with no side effects or issues.
Old 10-18-2009 | 03:09 AM
beebone's Avatar
beebone
Thanks u guys!
Old 10-18-2009 | 03:40 AM
CarbonRevo's Avatar
CarbonRevo
So should we just trace the line going back to the tank and put a little air breather on it?
Old 10-18-2009 | 11:46 AM
shiners780's Avatar
shiners780
That is correct. I used a very small fuel filter made for lawnmowers, since it was small and light. Anything will work, it just needs to keep debris from entering the line while allowing air to pass through.
The only disadvantage I can think of is you might notice a raw fuel smell at times. I don't notice it, even in my enclosed garage, unless I am under the car working on it. Even then it isn't too bad.
Old 10-18-2009 | 03:49 PM
eniac's Avatar
eniac
I noticed last week that the tiny autozone filter I had put on fell off at some point over the summer. I noticed no difference. In the future I plan to add a one way valve and extend the vent tube to mate up with the fill vent tube and expansion tank in the rear quater panel.
Everything going to the front of the car can be removed.
Quick Reply: Fuel Vapour Purge system Delete
