928 Forum 1978-1995
Sponsored by: 928 Specialists
How do you remove/disassemble the hatch upper latch? Now - Hatch rattle fix.
Old 06-15-2012, 02:01 AM
  #46
nexty226
nexty226's Avatar
I'll be interested in one or two. First name the price ,so it don't get me by surprise je. Im using my s weekly, because my pick up is being painted and don't have any option, but to use the car. My concern is to leave it open, that's why I need the pice ;-)
Old 06-15-2012, 02:06 AM
  #47
Ron_H
928 Barrister
Ron_H's Avatar
Nexty, can you use some JB Weld on that crack temporarily? I did that for awhile until I needed to finally change my latch. It will crack all the way through ultimately, but using epoxy will slow it down. Make sure you get the epoxy IN the crack and not on the side of the housing and make sure it cures well before reattaching to the body.
Old 06-15-2012, 02:15 AM
  #48
nexty226
nexty226's Avatar
Post
Well I do it tomorow in the shop, but you think the JB Weld is goinna stick the two parts together? Because it broke in half. Hope it work for a bit of time.
Old 06-15-2012, 02:51 AM
  #49
Ron_H
928 Barrister
Ron_H's Avatar
If it has already broken completely in half, I wouldn't bother with JB Weld. Just toss the part. When I used JB Weld there was only a hair line crack starting and I jammed it into the crack.
  #50
Bill Ball
Under the Lift
Bill Ball's Avatar
I tried JB - no luck. It flexed and broke again immediately. I waited a year for 928 Intl to come up with one that was not already cracked.
Old 06-15-2012, 03:07 AM
  #51
nexty226
nexty226's Avatar
Waoo a year, jummm that sounds bad. Im thinking what I can do now. I'll wait for brett ,to see if he has something ,but if not then I'll be in trouble. Let's wait until morning to ask my friends at the shop what they think about that may be someone thinks of something i don't know, but hey like my granny always said: always face bad times, with a smile, may be I find a solution very soon ;-)
Old 06-15-2012, 09:24 AM
  #52
Bilal928S4
Bilal928S4's Avatar
Dependent on price for the CNC part I would need 1 or 2.
Thanks for offering to make it.
Old 06-15-2012, 10:17 AM
  #53
fraggle
fraggle's Avatar
I need one. I'll suck up and pay for it, too. Looking forward to replacing both the housing and the plastic tongue.
I need one with an alarm, are you planning on two versions?
Old 06-15-2012, 11:47 AM
  #54
123
123's Avatar
Originally Posted by Ron_H
How many people are interested in my friend producing these latches (upper) in steel on a CNC machine?
Depending on price, I'd probably buy one.
Old 06-15-2012, 12:47 PM
  #55
nexty226
nexty226's Avatar
Name the price, the I'll see if the budget is enough for two.
Old 06-15-2012, 03:08 PM
  #56
ROG100
Basic Sponsor
ROG100's Avatar
As a base line consider the following ---
Purchase a upper hatch lock assembly without alarm and without a specified key. So the key does not match your original and the latch is a non alarm latch. New from Porsche these are $151.
Buy an alarm latch, pin and spring for $15.50 and retrofit including swaping in the alarm harness connection. Extract your lock from the old latch assembly and install in the new one.
Total cost $166.50 plus some shipping and a couple hours on the kitchen side.
I think a CNC copy is going to be much more than this possibly!
Old 06-15-2012, 03:44 PM
  #57
Bill Ball
Under the Lift
Bill Ball's Avatar
Roger - Does that idea actually work? I thought the the alarm and non-alarm housings were different, so the guts could not be swapped.
Old 06-15-2012, 03:46 PM
  #58
Bilal928S4
Bilal928S4's Avatar
Does anybody have a picture of a non alarm housing that they can post to see the differences in the two housings?
Old 06-15-2012, 09:10 PM
  #59
ROG100
Basic Sponsor
ROG100's Avatar
Hi Bill,
Looking at them side by side the only difference externally seems to be the separate plate where the alarm harness connector sits. This again looks like it could be swapped out.
Maybe a project for the weekend.
Worst case drop the alarm and be happy that the key does not match the rest. In my case no worries as I have remote unlock of the hatch.
Old 06-15-2012, 09:27 PM
  #60
Bill Ball
Under the Lift
Bill Ball's Avatar
Somewhere I got the impression that if an alarm housing cracked, you were stuck with replacing it with same. Super expensive new. Expensive used and rarely available. So, Roger if your idea works, that's a real plus.
Quick Reply: How do you remove/disassemble the hatch upper latch? Now - Hatch rattle fix.
