My Next Restoration Project 85.5
Old 10-05-2014, 06:46 AM
  #76
mazdaverx7
mazdaverx7's Avatar
Next step is to repair the sloppy shifter. I am following v2Rocket_aka944's writeup and using the thrust bearing and bolt repair. I ordered the parts from McMaster Carr yesterday and they should be here some time this week. I figured since the shifter pin has worn and tapered significantly, and the shift rod is probably no better, this repair should do the trick. I will post pics of this once I get the parts in the mail and start doing the repair!
Old 10-11-2014, 10:20 AM
  #77
mazdaverx7
mazdaverx7's Avatar
After repairing the shifter, I can honestly say that I am super pleased with how well it shifts. There is still a minor amount of play and I think I have to work that out at the transmission. Will post pics today of a lot of the progress that I've been making!
Old 10-11-2014, 11:19 AM
  #78
mazdaverx7
mazdaverx7's Avatar
The car has been back in the garage for a few days for the upcoming work.
First thing was removing the tape and paper from the door frame and weatherstripping. Using automotive Goo Gone:
Most of it came off of the weatherstripping bt I'm having a hard time getting it off of the metal:
Also started re-cleaning the engine bay. Got the corrosion off of the cam housing and got it cleaned up:
Old 10-12-2014, 11:55 PM
  #79
mazdaverx7
mazdaverx7's Avatar
After the dash cover was removed..The glue is still on there or it has discolored the dash. Seems as though the glue had been on there for well over a decade:
Old 11-22-2014, 09:38 AM
  #80
mazdaverx7
mazdaverx7's Avatar
Next phase is to replace the ISV hoses and vacuum lines. Long term winter project is a new clutch. But the good news is that I continue to work on the car weekly.
Old 11-25-2014, 09:06 AM
  #81
mazdaverx7
mazdaverx7's Avatar
Got the car back in the garage and am tracing a coolant leak. Looks to be the radiator and from the puddle something on the right side of the engine seems to be seeping. It in my leaks after the car is driven and then parked. A visual inspection revealed no obvious leaks. I'm wondering if the coolant drain plug on the block has a bad crush washer or if its slightly loose. Time to do some digging.
Old 11-25-2014, 01:37 PM
  #82
SOB Racing
SOB Racing's Avatar
Originally Posted by mazdaverx7
Windshield sealant applied to upper hatch area:
What did you use to seal the rear glass? Mine moves around in the "frame" when you open close it
Old 11-25-2014, 10:47 PM
  #83
mazdaverx7
mazdaverx7's Avatar
All I used was a window weld. I know its not the preferred method but it worked and was inexpensive. I got the tube at Home Depot.
Old 11-25-2014, 11:32 PM
  #84
SOB Racing
SOB Racing's Avatar
Thanks...that's what I was thinking of but couldn't remember the name!
Old 11-26-2014, 11:42 AM
  #85
joeystanker
joeystanker's Avatar
Mazda,
It's looking great! I have got to get the bits of corrosion of my car as well. It is here and there. Tape and goo and the like on a 944, I still can't imagine our cars with owners that didn't hold them in the highest regard.
Our cars deserve so much more than duct tape and gobs of glue.
They are works of art for Gawdsake, right fellas?!
Joey
Old 01-09-2015, 10:01 PM
  #86
mazdaverx7
mazdaverx7's Avatar
Finally got around to ordering the hoses for the idle control valve and the plastic clip and the metal retainer for the heater flap. Will be nice to fix the idle and get it so the heat works properly. As always I will update this thread with pics of the repair work.
Old 01-12-2015, 05:33 PM
  #87
mazdaverx7
mazdaverx7's Avatar
First wave of new parts came in today! I ordered quite a few more though, so I'm not sure when I'll start in on replacing things. The sooner I sell my 86 944, the sooner I can have this car back in the garage for good.
Old 01-22-2015, 01:35 PM
  #88
mazdaverx7
mazdaverx7's Avatar
Bunch of parts came in today so I'm going to pull the car in the garage and start in on replacing some of them today. I will add pictures as I am doing the repairs!
Old 01-22-2015, 02:57 PM
  #89
joeystanker
New parts, Yay! :-)
Old 01-22-2015, 03:40 PM
  #90
Dino V
Dino V's Avatar
Awesome, keep up the good work. Nothing more exciting than new parts delivered lol.
Quick Reply: My Next Restoration Project 85.5
