My Next Restoration Project 85.5
Old 05-06-2014, 01:00 AM
mazdaverx7
mazdaverx7's Avatar
Default My Next Restoration Project 85.5
Kinda been keeping this under wraps until I knew the deal was a go. Its a go and I may get the car as early as this weekend. I've been wanting an 85.5 and up for some time and this one spoke to me as a major restoration effort. So what if it hasn't been on the road in 10 years. Its deserving of a restoration and I will learn a lot by bringing this car back from an inevitable doom. It speaks to me not only because its a 944, but because it has some nice options and the car is mostly unmolested. Until I get the car in my garage, I can only share pics from the guy I'm getting it from. I decided to trade him my 84 Corvette for the car. Here are some pics:
Old 05-06-2014, 01:49 AM
mhariush
mhariush's Avatar
what color are those seats? Black?
Old 05-06-2014, 01:56 AM
mazdaverx7
mazdaverx7's Avatar
Yes they are black script seats.
Old 05-06-2014, 01:57 AM
mazdaverx7
mazdaverx7's Avatar
Here's a pic from a little farther back:
Old 05-06-2014, 03:24 AM
william_b_noble
william_b_noble's Avatar
I like the fuchs wheels, I got those on mine when I bought it (new). Looks like pretty good shape - some minor plastic parts missing, and the lower part of the door panel (the pocket part)
Old 05-06-2014, 01:21 PM
carlosvmata
carlosvmata's Avatar
With the exterior and interior looking like it is in pretty solid shape, what are you anticipating to be the "big issues"?
Old 05-06-2014, 02:28 PM
V2Rocket
Rainman
V2Rocket's Avatar
Nothing a healthy dose of elbow grease can't take care of.
Nice pick up.
Old 05-06-2014, 03:07 PM
mazdaverx7
mazdaverx7's Avatar
Well, the car has sat since 2003 and allegedly has not been started in over a year. Maybe more. So,to me this says first off, a complete timing belt/water pump/rollers job, complete fuel system refurb, and possibly a new tank, depending on how much of the gas has carmalized, (and if the tank comes down, I may as well install a new clutch, inspect the torque tube and replace the slave cylinder and hose as well as the clutch master cylinders) while the trans is out) injectors being sent out and professionally cleaned, all new filters, belts, hoses, vacuum lines, oil cooler seal, valve cover and cam tower gaskets, full tune up, and cooling system flush. That's just to get the thing running well.
Next on the agenda will be brakes, tires, and suspension work if need be.
I will also need a driver's side window and possibly a regulator as the window is missing all together and I will have no idea about the regulator until I get it in the garage in a few days.
Its also missing the driver's side door handle and the guy says the passenger side handle does not work.. So that means new door handles for sure and shortly thereafter, a new lock and ignition cylinder so that I have one key that will open the car.
Then, whatever doesn't work on the car, stereo, wipers, lighting, etc will also be addressed. Then its off to my dad's body shop for for body repairs and new paint.
Old 05-06-2014, 04:40 PM
porsche_dreamer
porsche_dreamer's Avatar
Was this car on craigslist? I swear I saw one just like it while browsing a while back.
Old 05-06-2014, 05:08 PM
mazdaverx7
mazdaverx7's Avatar
It was. I saw it and called the guy and we worked out a trade.
Old 05-07-2014, 03:00 PM
Dino V
Dino V's Avatar
Nice find and looking forward to seeing your progress on the car!
Old 05-07-2014, 03:55 PM
944Ross
944Ross's Avatar
Congrats! Looks like a real solid car.
Both of my 944's sat without running for 7+ years, one with a full tank of gas, the other empty. I strongly recommend putting an aftermarket filter ahead of the fuel pump, Summit sells Mr Gasket filters with 1/2" connections. I blew a new pump when sand came thru the stock outlet fitting, despite flushing the tank. I also had to manually pulse the injectors while running the pump to free them up.
Old 05-07-2014, 05:59 PM
mazdaverx7
mazdaverx7's Avatar
Good advice! I have considered replacing the gas tank but I won't know more until after Friday. I plan on going to get the car Friday evening. First thing for fuel system cleaning will be to send the injectors to witchhunter and have them cleaned and flow tested. I will also order all new filters.
I will continue to update this thread with plenty of pics of the restoration progress.
Old 05-07-2014, 06:46 PM
admiralkhole
admiralkhole's Avatar
I just picked up an 85.5 too, I started swapping my v8 and all other stuff from my '83 today! Let me know if you need any engine bay/motor parts.
I dig the script seats too!
Old 05-07-2014, 11:27 PM
mazdaverx7
mazdaverx7's Avatar
That sounds good. I'm sure there will be quite a few things I need.
Quick Reply: My Next Restoration Project 85.5
